how can I determin what size safety to use in a 1933 sparton radio
safety caps
Re: safety caps
Is there any writing on the cap, also check the schematic.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/ -
Re: safety caps
If it's the one across the mains.. we normally just bin them and don't replace..
Now if you want to.. usually they are 0.05 @ 1KV X2 class.. general mains motor suppressor caps are suitable.
I'm in the UK and our standards for such things are stricter.. mostly you will find them being 0.047uF (47nF) - X2 Class 275VAC
The circuit of the power wiring up to rectifier would assist us here.Comment
Re: safety caps
Do you want to install one? There was no X/Y safety cap type in 1933.
http://www.justradios.com/safetytips.htmlLast edited by budm; 12-10-2015, 12:30 PM.Never stop learning
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by momakaThis one should make @Pentium4 smile
(if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
Macron Power Technology Co. LTD.
Let’s look at the PSU itself.
The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of... -
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
- Loading...
