Re: Need help reading a schematic.
The output of the PIC PIN 2 net label K1 goes to the resistor R3 on the leg the resistor with net label 'K1' to turn on the the Transistor Q1 which drives relay K1 coil.
Pin 1 net label 'K2' of the PIC goes to R4 to turn on Q2 which drive K2 coil.
You have component designator, I.E.: K1, R1, C1, etc.
R2 is a 16 ohm resistor. I don't know why the value isn't listed on the schematic.Leave a comment:
It's a bit of a Euro schematic - and some people like to run wires all over and some like to use Nets.
I think you are getting mixed up with component pin names and net labels. Also Belgium has three official languages: Dutch, French, and German so abbreviations are tough to figure out. You would have to ask what "S" and "O" mean in that language.
The contrast pot has pins A,E,S (in English usually CW clockwise, CCW, wiper/slider) and the wiper pin "S" goes to Net CONTRAST which only goes to the LCD header pin 3. So the pin name "S" and Net name "CONTRAST" are connected to each other.
The relays have pins O,S,P (in English NC, NO, COM) and here the "S" pin goes to connectors X#-2. It has no connection to the "S" pin on the trimpot because they are different components.
PIC K1 and K2 Net labels (signals) only go to the 1k resistors. Their (Net) name is confusing with components K1 and K2 and not the clearest way to do a schematic.
The common terminal on the relays "P" go to connectors X3-1 and X5-1 only. Not the PIC - you don't want the PIC getting high power going to its pins.
Resistor R2 sets backlight LED current but has no value.Last edited by Spork Schivago; 11-15-2015, 10:54 PM.Leave a comment:
Resistor R2 sets backlight LED current but has no value.Leave a comment:
The wiper of the pot P1 pin S (net label named 'Contrast') is connected to the LCD1 connector pin 3 (net label named 'Contrast'). As you can see there are only two net label with the same name 'Contrast' so those to are electrically connected together. You should learn more about net label to understand what it is and what it is used for in the schematic.
Do not get confuse between the component pin names with net label.
For example the pot P1 as shown in the diagram, there are 3 electrical pins: pin 'A', pin 'E', and pin 'S'.
I'll do a bit more research on the net labels as well. Thank you!!!Leave a comment:
'Also, for X3-1 and X5-1, do I just tie them together because they both say O and then send them off to the PIC where it says K1 and K2? And what does the P stand for under K1 and K2? Is that just the power to the relays?'
'do I just tie them together' No.
Relay has 5 pin names: Pin '1' and Pin '2' are for the relay coil, then there are 3 pins for the relay contacts, Pin 'P' is the Common pin, Pin 'O' is the Normally Closed contact, pin 'S' is the normally OPEN contact. When the relay is energized, the pin 'P' will then make contact with pin S', pin 'O' is then no longer make contact with pin 'P'.Last edited by budm; 11-15-2015, 10:39 PM.Leave a comment:
I'm trying to learn how to build circuit boards. I ordered a kit off the net for a digital timer. Essentially, it's powered by a PIC and it has an LCD screen that gets connected to it. You program an amount of time and then it will provide power to another board that has a bunch of UV LEDs on them. You just use transparencies and photoresist boards with this kit and you get real nice circuit boards I guess.
Anyway, I've downloaded Eagle and I'm trying to create a schematic for the timer board. The guy who sells the kits provide schematics and board layouts, but they're all in PDF format. Eventually, I'd like to modify the design a bit so the power supply and the timer are all on one board.
I'm having trouble reading the schematic though. I've attached a copy. They use some different symbols, European ones I think they are. But I have a few questions I was hoping some one could help me out on. On the potentiometer located at A-6 (upper right corner), I see there's a pin that says S CONTRAST. And a bit further down in the schematic (B & C 4 - 5) there's some screw type connectors (to hook wires up to) that say X3-2 and X5-2. They both say S. Does the potentiometer go to both of those S's and to CONTRAST on the 16-pin header for the LCD screen?
Any help would be greatly appreciated. Thank you.Attached FilesTags: None
by waigyIn my fusion FE-402 car amplifier the gain pot is an RK097G.
I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
I then took the pot out the board and it now measured 22k.
I tried putting it back in the board and it goes back to 10k.
Is this normal and if so what pot should I order?
On this... -
by DeanWyHi all,
I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
There... -
by gjgibHello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,... -
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by atunguydIi wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...-
Channel: Schematics and Boardviews
- Loading...
