Re: Need help reading a schematic.
Will do.
to find the best temps, look at the datasheets for the solder & flux.Leave a comment:
10 boards down, two more to go!!!! Then I just need to find some solderable flat pieces of metal to attach them all together.Leave a comment:
I tried the 590F (310C) and it worked but took a bit longer to melt the solder. Is there any dangers to using a higher temp? When I set it to 630F (332C), that seemed to work the best.Leave a comment:
Thanks! I'll give it a shot later. I usually was using 600F for the soldering when I was using the silver stuff and then 650 when I was desoldering. I'll give the 590F (310C) a shot and see how well that works.Leave a comment:
i use 310 for everything other than low-temperature soldering with 5% silver solder.Leave a comment:
Thanks! Like these? http://www.all-spec.com/products/801...FUgXHwodAlwOoALeave a comment:
343' seems high, i solder at 310' with lead-free solder.Leave a comment:
I've seen this method done in videos but when I try I mess up horrible! I tip my hat to anyone that can do it that way. It's simply amazing! My hands shake pretty bad sometimes. Usually it isn't that noticeable until I work on smaller stuff. That makes it a bit harder. Eye sight isn't great either so I usually use a magnifying glass while I'm soldering.Leave a comment:
I just burned myself on this Weller! It's the first time on this iron! 650 degrees F (around 343 C). It left a nice white mark on my finger where the iron touched. It's about 1/4" (6 - 7 mm) long. Boy does it hurt!Leave a comment:
I'm currently uses these from Radio Shack:
https://www.radioshack.com/products/...ant=5717833157
They're okay for cutting wires but for leads, they just more or less smush the metal. Maybe it's because they're not sharp enough?Leave a comment:
cant find a good foto, but you want a pair where the blade is ground on the inside only.
they are usually called "flush cutters"Leave a comment:
your cutters are making that look, get a pair with a flush-blade on the outer edge.
factory's used to use a saw to trim all the leads years ago,
now the leads are pre-cut before they are auto-inserted.
you can see this with some of the ebay chinese cap sellers who are selling surplus from production-lines.Leave a comment:
So with the needle and the flux it is easy to use. Just small amount on the pad and solder. With the right tip on the iron one just puts some solder in the tip and just pull it down on the edge of the component leg. One pin after another without stopping. Just add a little solder when it get used up. If for some reason a solder short appears then apply flux and heat up. The solder will go to the pads. A good solder joint on Surface Mount will be on the outside edges of the leg of the component. So it will be from the edge of the component leg to the pad on three sides of the component leg. This is easily accomplish with a hoofer tip or a bent beveled tip that is about the size of the leg being solder. Should be able to solder a 14 pin IC in a matter of seconds.Leave a comment:
On a side note, when I clip the leads off the through-hole UV LEDs, the wire snippers I use cut the leads leave them a bit smushy looking. They definitely don't look like a professionally done PCB. Is there a better way to cut these leads? How do they do it at the factories?
Man, I had a scare! Took me a bit to figure it out. Soldered all the UV LEDs on the board and one whole column (four UV LEDs) didn't light up at all! I thought for sure it was the trace. I went through and touched a soldering iron to each one, hoping it was a cold solder joint or something. No go. I looked at the schematic and board layout and studied how the lights were actually ran for those four non-working UV LEDs.
Then I went back in the work room and tried putting the ground on my PSU to the ground lead on one of the non-working UV LEDs. This got most of them working, except one. But the three that lit up weren't very bright. I started looking at the one that wasn't lit up and realized I put it in backwards! If I had cut the leads off the LEDs before testing it, I probably wouldn't of figured this out as easy like! Works like a charm now.
I went back through and checked the other two boards that I had already finished to make sure all of them actually lit up. One of them is different though. I even remember when I soldering, one UV LED had much longer leads. I want to say it's the same UV LED. It looks like maybe someone else made it. All the other ones glow the same colour but this one is much deeper in colour. Would this make a difference when I go to transfer the picture to the PCBs? Should I replace it with another UV LED? Thanks!Leave a comment:
So the power supply powers the UV Exposure Time circuit board, which powers the UV LEDs. The power supply should have a fuse in it I'm thinking but is it possible that the power supply would break in such a way where it could fry the exposure time circuit board? Would it be a good idea to add a fuse to that circuit board or don't power supplies usually break like that?Leave a comment:
Thanks! First time I've successfully used the hot air rework station to actually solder something. It's great for removing stuff. Glad I didn't have much problems.
On a side note, when I clip the leads off the through-hole UV LEDs, the wire snippers I use cut the leads leave them a bit smushy looking. They definitely don't look like a professionally done PCB. Is there a better way to cut these leads? How do they do it at the factories?Leave a comment:
by waigyIn my fusion FE-402 car amplifier the gain pot is an RK097G.
I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
I then took the pot out the board and it now measured 22k.
I tried putting it back in the board and it goes back to 10k.
Is this normal and if so what pot should I order?
On this... -
by DeanWyHi all,
I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
There... -
by gjgibHello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,... -
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by atunguydIi wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...-
Channel: Schematics and Boardviews
- Loading...
