Custom LED project, can anyone help?
  • WHaThEFLuX
    • Feb 2015
    • 277
    Re: Custom LED project, can anyone help?
    Wow, I can't believe that information was right in front of me! It looks like I'll be going with the NTE3078 then, was I correct in assuming that VSS on the MM5450 will go to ground on the REV A. board?
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
    • fzabkar
      • Mar 2009
      • 772
      Yes, VSS is ground. Best of luck.
      BTW, if you compare your bitmap against the one in the Lite-On datasheet, you will see why your display was garbled.
      • WHaThEFLuX
        • Feb 2015
        • 277
        It's all so clear now, I can't thank you enough for your advice!
        -retiredcaps
        • WHaThEFLuX
          • Feb 2015
          • 277
          My last question concerning this project is the type of components I need to make this custom setup function.
          I believe I need a capacitor and a 100K resistor, can anyone let me know if this is correct and if so what kind of capacitor I should use?
          Figure 13 :
          http://www.micrel.com/_PDF/mm5450.pdf
          -retiredcaps
          • fzabkar
            • Mar 2009
            • 772
            Those components are external to the original module. They should be on the PCB. There should be no need to add your own.
              • 31283
              do yourself a big favour and dont by any ancient / b-grade parts that have been re-labelled "NTE"
              go buy new parts from "real" manufacturers with "real" part numbers.
              • WHaThEFLuX
                • Feb 2015
                • 277
                I'll be making my own pcb to put the mm5450 on along with the digits so I can have traces instead of a bunch of wires, so will I still need the components?
                -retiredcaps
                • fzabkar
                  • Mar 2009
                  • 772
                  I assume you are just making a daughter PCB that will connect to the main PCB via a 7-pin header. If so, then you don't need additional brightness RC components on your daughter PCB.
