Polyester Capacitor ESR
  • darjness
    • Nov 2012
    • 31
    • Portugal
    What should a polyester capacitor 22nf 1000vh ESR should be ? I´m getting ~77 Ohms.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Polyester Capacitor ESR
    ESR measurement is irrelevant for caps under 1uF as capacitive reactance at the measurement frequency comes into play too as the capacitance goes lower. Use a regular capacitance meter to measure those.
    A working TV? How boring!
    • darjness
      • Nov 2012
      • 31
      • Portugal
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • Fritter
        Power supply filter capacitor measurement in circuit
        by Fritter
        Hi
        Measuring a 400v 330uf capacitor across the bridge rectifier and in circuit with a multimeter on ohms. Measures 360 ohms both ways when polarity on the meter is changed. If this is normal, I'd like a brief lesson
        11-15-2023, 12:58 PM
