My Samsung ue32f5000ak has a blank screen but has sound
  • YeOldeGinge
    • Nov 2014
    • 30
    • Telford and Wrekin
    My Samsung ue32f5000ak has had a blank screen but had sound and i have got to the point where i have found the problem which was a faulty LED on the LED strip for the back lighting but i was wondering if I bridge the connection of the led so it doesnt use the LED would it cause any additional damage? or should i just wait and order an led?
  • mrtek
    Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
    by mrtek
    Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
    11-26-2024, 09:58 AM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • mecha1166
    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
    by mecha1166
    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
    11-25-2024, 05:22 PM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • mar1in
    Samsung TU8000, backlight and sound on, stuck in blue screen
    by mar1in
    I've got this Samsung here that would be stuck in a boot loop.
    After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
    Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
    Thanks in advance
    11-08-2023, 05:43 PM
