Desoldering Caps With Hot Air.
  • Techstar
    Tv Restoration
    • Dec 2012
    • 122
    • United Kingdom.
    I am considering buying a Hot Air System for practice at de soldering flatpack chips. There are some nice ones for sale on e bay for around the 60 pounds mark. Do any of you guys use these for removing Caps and other small single components . I have noticed the PCB trace is easy to damage by lifting component when small amount of solder is still there, on some boards , do you think a re work station could help in making neater less damaging repairs when pulling components.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Desoldering Caps With Hot Air.
    Perhaps if traces are getting damaged then the iron isn't hot enough or the solder isn't fully melting.
    I sometimes use hot air but you have to be careful you don't move small components with too higher an air speed.
    Not sure if its a figure of speech but there should be no pulling of surface mount components, just a gentle lifting.
    • redwire
      • Dec 2010
      • 3912
      It's a good question - how best to de-solder smt electrolytic caps?
      You have to heat up the long PCB pads, underneath the cap - so I don't see hot air working because the capacitor's body is in the way of the heat. I haven't tried hot air on a electrolytic yet.
      Lately I use a soldering iron and a lot of heat. But still pads get ripped off.
      • mariushm
        • May 2011
        • 3799
        It depends if you want to reuse the capacitor or not.
        If you don't care about it, easiest way to remove a capacitor is to gently twist the smt capacitor back and forth a few times until the wires break. Then, a drop of flux on pads and a tip with fresh solder will remove the old tabs that are still soldered to the tabs.
        See the procedure explained here, at 10:35 : https://youtu.be/p1zhfYHUIIY?t=10m34s or this one at 5:50 : https://youtu.be/3-5UsS49170?t=5m53s
        If you care about them, just flux the tabs, add solder to the tabs, then keep touching each tab for a second or so with your soldering iron... once both tabs are hot enough, a gentle nudge will move the capacitor away from that location
        You can desolder things with hot air gun, but imho hot air gun is best used for ceramic capacitors and resistors, or for small ICs in soic footprints or sot-223, dpak etc, stuff that has small pins. Wet the parts with flux (helps with heat transfer), use hot air gun, if needed drag a iron tip with fresh solder over the pins and you're basically ready to remove the part.
        • Techstar
          Tv Restoration
          • Dec 2012
          • 122
          • United Kingdom.
          Thanks for your advice people.
            • 31277
            trying to remove smd electrolytics without hot-tweezers is very hard and risky.
            if you try to do one side at a time you lift pads, if you use air the cap explodes!!
            i fucking hate those caps!
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Yeah, as STJ said, be careful! The caps can explode if you heat them up too much. Be sure to wear safety goggles.
              -Ben
              Muh-soggy-knee
              • Agent24
                I see dead caps
                • Oct 2007
                • 5085
                • New Zealand
                For SMD chip electrolytics, I just use two soldering irons as if they were a pair of hot tweezers. You need both hands,, but it works fine for me anyway.
                -David VanHorn
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
