I'm making a small board to sense 5v from a computer and turn on a xbox 360 power supply if the 5v is present.
I need a transistor / FET that can be controlled by a gate voltage of 5v or less, and can handle very tiny currents.
The 360 power brick has a 5vsb and expects 3.1V on the power_on and uses 75mA in the detection of power_on I assume id want to use a roughly 2000 ohm capacitor to drop the 5vsb down to 3.1v, assuming the fet had no resistance / current drop.
Anyways how should I go about picking a transistor / fet for this?
If I go to mouser and look at mosfet's I assume I need n-channel, gate-source threshold voltage around 1-1.5v? (since source will be at 3.1v after the 2000ohm resistor) What else should I be worried about?
