atmega328p vs atmega168
  • synapsea
    • May 2015
    • 6
    • Shkoder
    whats the diference? i think they are the same
  • lti
    • May 2011
    • 2555
    Re: atmega328p vs atmega168
    They have different amounts of memory.
    See section 2.2 on page 7:
    http://www.atmel.com/Images/Atmel-82...et_Summary.pdf
      • 31139
      for a start, anything with "p" on the end is pico-power and can run at much lower voltage & current.
      http://www.atmel.com/devices/ATMEGA1...tab=parameters
      http://www.atmel.com/devices/ATMEGA3...tab=parameters
      • synapsea
        • May 2015
        • 6
        • Shkoder
        thanks iti and stj this really help me
          • 31139
          are you making something?
          • synapsea
            • May 2015
            • 6
            • Shkoder
            yes i already make arduino uno but the computer does not recognise it. do u think the atmega dont have bootloader?
              • 31139
              it would need one.
              personally i woud skip that old crap and look at the ST NUCLEO boards.
              they are 32bit ARM core with onboard usb for less than the cheapest arduino
              best is this:
              http://uk.farnell.com/stmicroelectro...bed/dp/2491978
              • Biruslapio
                Reprogram Philips 32PFL3008D Winbond EEPROM with ATMEGA328P
                by Biruslapio
                I've shearched before posting this, and found dozens of different ways to hook up multiple types of EEPROM to an Arduino Uno, so I do not know which one is correct.
                I need to learn this so I ended up with a Philips TV 32PFL3008D which has corrupted memory, the IC is U402, 25Q64FVSIG, I have the 3MB .bin file, how to hook up an ATMEGA328P to this memory and what code do I need?...
                12-03-2021, 08:33 AM
                Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                Securing a good thermal interface between...
                10-07-2024, 04:35 AM
              • sircastor
                Solder not reflowing - what am I doing wrong?
                by sircastor
                I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                03-03-2024, 02:44 AM
              • harp
                Any kind of IC programmer
                by harp
                I recently watched a video, which claims the possibility of programming different types of chips with arduino - just unsolder the atmega328p and connect to the rx and tx pins is a summary...
                https://www.youtube.com/watch?v=6yJ4GbJH_TU
                however, there are universal programmers that supposedly can program many chips, even over 100000+ are listed...
                https://www.advin.com/universal-prog...list-6100N.htm
                Since they all work automatically through the software, the interior of the programmer is very complex, but it indicates that...
                04-05-2023, 12:11 PM
              • mik13ST
                Resetting old Repotec/Eusso switch without RST button or admin access
                by mik13ST
                So I have a Repotec RP-G3224V that a friend recently gave me so I can try to sell it or reuse in other way (can always disassemble for parts, but that's the last option). He bought it used online in "as is" condition many years ago. I tested the connectivity between the ports and found some configured isolated groups (see port isolation map.png). I want to reset this configuration so all are connected together, however there is no reset button anywhere and the credentials for admin access over RS232 console are not "admin / admin" or "admin / 123...". I considered...
                03-14-2023, 12:12 PM
