LG Flatron Cap substitute
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 661
    • samsara
    The monitor displayed black stalactites on about the top 10th of the screen.
    So i pulled it apart and found a samxon GL with a domed and popped bung.
    So will Recap it
    All the rest are samxon GL, except for one tiny 0.47 50v samxon KM
    There is two 33uf 50v caps of which i am not sure if i have adequate replacement:
    (Only have Limited choices from supplier with free shipping for a limited time - but unfortunately none of the usual replacements are available for these caps.)
    PW is the closest match for ripple and impedance
    The original samxons have ripple rating of 295mA and Impedence rating of 0.30
    The PW's have ripple rating of 300mA and impedance rating of 0.43 (under same conditions)
    One of the capacitors is connected to the transformer, and the other is on the same 'rail' that one side of the faulty cap was on (the other side of the faulty cap is on a 'rail' which is connected to the 2 "12v" pins on the big connector socket)
    So just making sure that it is cool to replace both of these caps with PW's - considering that one is on the input side, and the other is on the output side
    On another thread Th3_uN1Qu3 said "but variations of +/-50% are perfectly acceptable for ESR as well." - but that was regarding a video card - so i'm not sure if thus rule of thumb would apply to both primary and secondary sides of a LCD monitor power supply
    Also, for the little 0.47 50v samxon KM 7mA ripple with unknown impedance (next to the transformer), would it be OK to replace it with a rubycon YXJ rated at 17mA ripple (105deg/100khz) and 12ohm impedance?
    • 31139
    Re: LG Flatron Cap substitute
    forget the PW's
    ripple can be higher, but never lower - atleast not worth risking it
    ESR can be lower but never go higher unless it's just 0.01ohms or so difference.
    what's the supplier address?
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      You don't have to replace the 0.47uF. It's such a small value, and KM is much more reliable than the known bad Samxon series.
      This will be an okay replacement. In this case I'd take ripple rating over ESR. In that place, ESR isn't insanely critical
      • socketa
        Asbelowsoabove
        • Jun 2014
        • 661
        • samsara
        http://nz.element14.com
        OK,
        i was stuck on not changing the capacitance.
        So how about Panasonic FR 47uf 405 ripple and 0.14 impedance
        or XYJ 47uf 295 ripple and 0.3 impedance
        These two sound like better replacements.
        So is it better to look at increasing the capacitance a bit, while keeping the ripple and impedance within original specs?
          • 31139
          yes to all that.
          and FR is my prefered cap in just about anything other than motherboards.
          • socketa
            Asbelowsoabove
            • Jun 2014
            • 661
            • samsara
            Just noticed that the XYJ has exactly the same ripple and impedance, except that it is 47uf instead of 33uf, and 63v instead of 50v
            The FR has 405 ripple instead of 295, 0.14 impedance instead of 0.30, and capacitance of 47uf instead of 33uf, while voltage remains the same.
            Could the impedance on the FR be a bit too low, or are they both very much acceptable replacements?
              • 31139
              use either.
              i suspect the FR is cheaper even though it's a better part.
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • Y. Signal
                Recapping Mean Well MWP-606
                by Y. Signal
                Hello, I have this arcade power supply that I'd like to recap for maximum reliability and lifetime since I have found some Capxon and Jamicon capacitors:
                • Capxon GL 10x25 1000uf 16V Ripple: 1180 Impedance: 0.05ohm // Chemi-con KY 1000uf 16V Ripple: 1400 Impedance: 0.046ohm
                • Capxon GL 10x12.5 470uf 16V Ripple: 722 Impedance: 0.095ohm
                • Capxon GS 10x15 22uf 50V 85ºC Ripple: 100
                • Capxon KM 47uf 50V Ripple: 125
                • Jamicon TK 1uf 50V Ripple: 12
                • Jamicon TK 4.7uf 50V Ripple: 36
                I have another PSU (same model) that uses Chemi-con KY instead of Capxon GL, and since Panasonic FC are very...
                03-03-2019, 07:44 AM
              • Antonynl
                What are typical ripple voltages on a laptop motherboard?
                by Antonynl
                I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                So I have two questions:
                1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                12-09-2022, 06:51 AM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • ADV
                Acer Ferrari F-20" monitor display interference and replacement capacitor selection
                by ADV
                Good day everybody
                I hope I'm posting in the right section - I am new to this awesome forum.
                I have received an ACER Ferrari F-20" LCD Monitor to repair.
                It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
                For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
                I opened the external 18V power supply and see no bulged capacitors...
                11-02-2021, 09:32 AM
