need some help with unknow component.
  • shlomi93
    • Apr 2015
    • 10
    • israel
    hey guys.
    so im trying to fix a monitor and i have on the board TO92 component
    the component is A1 AS431A CO828
    now the pins on the board is R A C
    REF
    ANODE
    CATHODE
    but i dont know what component have R C A pin out.
    im a beginner.
    please help me to identify this component becuse i really donst get it.
    and if i cannot fine the same component what can i solder instead?
    datasheet Attached.
    thanks in advance.
    • 31283
    Re: need some help with unknow component.
    431 voltage reference.
    very common - the letters change but the part does not.
    TL431 is the most common.
    • shlomi93
      • Apr 2015
      • 10
      • israel
      what?
      so R C A = C B E ?
      and how do i test this component with DMM ? i already desolded it from the board..
      • mariushm
        • May 2011
        • 3799
        It's not a transistor, so there's no collector, base and emitter. It's sort of a diode.
        See http://www.homemade-circuits.com/201...regulator.html
        Try to use Google from time to time, it's often faster than waiting for answers on a forum.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          No, it is a voltage regulator IC. Think of it like a variable zener diode.
          • rievax_60
            • May 2012
            • 897
            • australia
            That link has useful information.
            I have never tested a TL431 with a meter. Red to A and Black to C on diode test should read open. Connecting R to A should cause a 2.5v reading or slightly less.
            Never run a power supply with the TL431 removed. It is an important part of the voltage regulation loop.
