Voltage rating on SMD capacitors
  • akis
    • Jun 2012
    • 20
    I am using three SMD MLCC X7R 10uF/25V (total 30uF measured 40uF) at the output of a push-pull amp powered by +/-23V, the other side of the cap being a transformer.
    On a purely resistive load I think I'd be within the voltage levels of the cap.
    It is possible depending on the behaviour of the load on the transformer that higher voltages may develop even for very short periods of time.
    Can these theoretical (not observed, just academic) voltages harm the capacitor? How could I check a random capacitor for "good operation" other than plugging it on the cap meter?
  • akis
    • Jun 2012
    • 20
    Re: Voltage rating on SMD capacitors
    /bump
    anyone?
    • mariushm
      • May 2011
      • 3799
      Never a good idea to get the voltage so close. Your voltage can go higher than +/- 23v for sure, depending on your mains voltage, load (transformers output more when there's little load usually)
      But the worst thing is ... those ceramic capacitors won't be 10uF with 23v on them, they're probably going to be 3-5 uF if you're lucky.
      Read up on it :
      * http://www.maximintegrated.com/en/ap...ex.mvp/id/5527
      * video EEVblog #626 - Ceramic Capacitor Voltage Dependency : https://www.youtube.com/watch?v=2MQyQUkwmMk
      * video TDK Tech Tube : DC Bias Effect on Multilayer Ceramic Capacitors (MLCC) https://www.youtube.com/watch?v=weUrWSFJCgk
      You would probably have to use 100v rated capacitors and probably aim for more capacitance.
      • akis
        • Jun 2012
        • 20
        Alright I am reading and will now run some tests on my caps to see how they behave! What I was worried about was that reaching or exceeding the voltage ratings might cause irreversible damage, maybe even unnoticeable. like temperature coefficient worsening, or ESR worsening or whatever the capacitor meter won't tell me.
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
        • Instafixx
          Macbook A2179 820-01958
          by Instafixx
          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
          I checked the Power Sequences below and found this -
          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
          05-20-2023, 05:19 AM
        • hikomalek
          SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
          by hikomalek
          Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
          When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
          Transformer:
          |Info| Primary | Aux | AB | CD|
          |Ratio|1|25|40|12|
          |Voltage AC|230V|9.2V|5.8V|19V|
          |Voltage DC (*1.41)|230V|13V|8.1V|27V|
          I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
          09-19-2025, 03:30 AM
        • bimole
          Weird behavior on 3.3V rail of a CORSAIR CX600
          by bimole
          A colleague gave me an apparently ill CORSAIR CX600.
          He told me that he heard a banging noise, and smelt the magic smoke.
          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
          It's another story on the 3.3V rail...
          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
          02-13-2025, 04:49 AM
        • Fernon@Repair
          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
          by Fernon@Repair
          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
          VCCIO voltage ok
          VCCSA Voltage OK
          VCCPLL Voltage OK
          Ram Voltage ok
          RamVTT OK
          VPP 2.5 OK
          But No Core Voltage
          and i want to this vrm ic datasheet or pinout (ISL69269)
          anyone have this ic pinout voltages?...
          06-25-2025, 07:19 AM
