Outside AC Unit Contactor Wiring Question
  • TractorGear
    • Mar 2015
    • 40
    Second Title:
    Did John Wayne Air Conditioning Deliberately Fuck-Up my A/C Unit's Contactor's Wiring in Order to Sell me a New System?
    I'm framing this in the theoretical right now because I haven't got the pictures handy, but I have a "before" and an "after" that I can't get to right now, but I DO have time to post so I'm making the most of what I have right now, which is time to post not time to dig around trying to upload photos. The answer may not require them, however if it does I can post them later today, tonight, tomorrow.
    I did Home Depot's spring A/C "Tune-Up" thing, and they sent a (former Marine) Salesman er, I mean "Tech" out to the house for $40, which was primarily intended to be the cost of the 3+ cans of coil cleaning solution that costs $6.50 a can and I usually use 4 of them, so that was in my heart at the time I made the appointment. And also my full knowledge that we were never going to be talked into a $2,500 system while the old one is still wobbling around on it's last legs. I KNOW the outside unit's fan's bearings is going out, failure imminent, etc... it's been making that horrible noise for the last 3 years or more. It might continue to make that noise for another 3 years, and the bearings are non-replaceable, the fan is 20+ years old (no replacement assemblies or end-items either).
    So if the girl with the big Ba-ZOOMS wants to have a Tech come out to my house and drop 4 X $6.50 ($26.00) in coil cleaner in my outside unit for $40, and have me ask a few questions about whether or not preventatively replacing the various, large, $10.00 (on eBay) "start-up" capacitors (there are three, I learned), then why not. Besides that, I was out-numbered 4:1, and was outvoted by a large (75%) majority.
    Well the former Marine Sales -er I mean Service Technician was kind of pissy when I told him right up front that he was there to teach me everything I need to know in order to do all the work myself, and I was going to follow him around, ask questions, take notes, second-guess why something was condemned as "bad" and/or determined to be "good". Voltages, resistance, current draw, tolerances, and whether or not any of it would affect efficiency (as measured by this summer's electric bills), etc...
    I'm so nice. I'm SO nice. When he says "You aren't going to make me clean the outside unit's coils, are you?" and given the piteous tone of this poor, former Marine's face, I decided that in honor of all the brave men that died on faraway beaches like Tarawa and Okinawa and Iwo Jima and in places like A Shau valley, I decided that he'd been through enough (poor, tubby thing) and so I let him off the hook.
    Real Reason: Why "make" an uncooperative and reluctant workman do a half-assed job when you are going to do it yourself (and right) anyways?
    So, I gave myself permission to be a real pain in the ass, and asked a lot of really hard questions like "How does he know what that particular compressor's pressures are supposed to be." which was then followed-up with the long story titled "Two Years Ago", which details the long day 3 different crews of A/C Repairman spent looking at and wondering about our system until the Really Old Man That Knew Everything showed up and illuminated the fact that our house had been in a fire (before we moved in) and they replaced the inside unit but not the outside unit, so if you look up in a manual for the pressures of the inside unit, they will be wrong for the outside unit to work. And if you looked up the pressures for the outside unit, the inside unit would not work.
    And so, The Really Old Man That Knew Everything (ancient, almost 50) said that the solution to the whole, head-scratching situation was to effect a "compromise" of pressures so that certain pressures would be neither too high or too low for either the inside or outside units.
    Which, after some brief directions, the compliant "Young Men That Only Knew Certain Things" then implemented, and the A/C has run just fine ever since, which was (title) Two Years Ago.
    With the underlying message of "don't fuck with it, or you'll break it and be very,very sorry". And he didn't.
    So, he leaves and a week later I decide it's time to change the Contactor, because the contacts are burned and sometimes it makes a buzzing, arcing sound. And ever since that time, the outside unit's fan stays constantly on, and will only turn off when I pull the fuse to the whole unit.
    It's a single pole contactor, which I think means that one side is "always felt" and the other side is switched. I've figured-out which are the 24 volt DC lines, and which are the 110 VAC compressor and outside unit fan lines.
    When the (new) Contactor operates, the compressor gets it's 110 VAC like it is supposed to, but the fan does not. It's wired to the "always felt" side of the Contactor. I think I should simply move it to the "switched" side, but don't want to blow it all up.
    But the main question is how this happened? I took a picture "before" and it's wired "after" exactly the same, if my understanding of how the Contactor is arranged (left is "always felt" and right is "switched"). My new Contactor looks very different, but it's single pole, and the wiring is electrically the same. I took a multimeter and measured opens & shorts and then voltages, so I am certain my understanding of where 24 VDC and 110VAC is (and is not), and also which electrical points are always short (left side, front to back) and which are switched (right side, front to back). I even mechanically operated the switch to prove that certain points were always short, no matter what the contactor (switch) did, and that certain points where short when the switch was closed (but they were NOT short to the "always felt" (left) side.
    If you followed that, then I have either proved I understand the thing, or demonstrated that I don't know. I'm curious as to which.
    Assuming that I understand it, and have wired it all as a duplicate (which doesn't work) instead of how I think it should be (which SHOULD work), I want to know either why the old Contactor is different, or how it got wired wrong. The old one is off now, so I can't replicate it's previous state, but if the old Contactor was wired wrong BEFORE the former Marine AC Repair er- I mean Service Technician got there, then the fan would have run 24/7 all day long and every day, which it did NOT. Or, somehow I managed to mix up the wires myself before I took the photo (possible, I have ADHD like a mofo), or SNM ("Said Named Marine") did something tricky and funky with my wiring as a final, parting shot across the bow ("Buy our overpriced AC units or ELSE!"). I just think of all those dead Marines, laying there and wondering why they were so stupid as to die on some beach somewhere, so that this guy could rookie-do my wiring in order to make me have to spend money on something I really don't need.
    And, in case you haven't figured it out, I also served, so the whole "honor" issue is of great concern to me.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Outside AC Unit Contactor Wiring Question
    i would have to see it.
    Follow the white rabbit.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Contactor coil gets 24V AC. The compressor and fan get 240V, it does not matter if it's a single or double pole contactor.
      We don't use pressures exclusively to check charge. Superheat (if cap tube), or subcooling if TXV. Pressures tell you saturated temps on both hi and low side. With mismatched indoor and outdoor units, pressures will never look "typical." The usual lack of return air will lower the SST, too.
      Do not adjust charge until at least outdoor coil has been cleaned, and filters changed.
      http://www.udarrell.com/ac-trouble-s...ubcooling.html
      As to the unit not running(?), there was a company near here that got in trouble. They'd be called out for the "winter tune up," during which someone would cut the yellow wire in the furnace or AHU, "guaranteeing" a service call in the summer.
      People got wise to this, and some called in a reputable service co, whose guys immediately saw where Y was cut.
      If the compressor is running but the fan is not, stop. You'll have high head pressure and temps. If the lead wires inside the dome, leading to the stator, have worn insulation from the compressor "kicking" around over the years, that insulation can break down and short the compressor out.
      Do not run the outdoor unit w/o its fan!
      That fan has a run cap; only very old units from the 70's didn't. Those used a shaded-pole motor instead.
      Check the run caps, there's one for the compressor too. It's common for both caps to be in a single can.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • TractorGear
        • Mar 2015
        • 40
        What is the "SST"? I got "Single Shot Transistor" or "Sub-Surface Telephone", etc...
        The "return air" shares the same air as the garage. The inside unit sits with the top completely exposed to the attic and I could gut every single member of the crew that installed it with a K-Bar, so that their guts all go splat into a large, white vinyl tub, and I send those guts to their mothers, wives and daughters as a permanent expression of the level of contempt I have for dishonest workman that do half-assed work and it's also over-priced. My Mentor's rent house had a duct laying on the floor of the attic, disconnected, and the tenant complained about high electric bills for years. One guy leaves it disconnected; the next guy gets paid to reconnect it. And then everyone sings praises about how good "the next guy" was, as a direct result of him not telling them that the previous guy left the duct work disconnected, out of malice or neglect I cannot say. Either way, I propose the K-Bar solution. Take a couple of them out and the rest will realize it's safer to do honest work at a fair price.
        I doing what you could call "taking A/C repair standards to a whole new level". The level where the penalty for failure is a fate worse than death. These people make their money based on people's unwillingness to think of John Wayne as an incompetent crook that took advantage of people's trusting nature and their love of an American Hero. In my John Wayne movie, the owner of the A/C Repair company gets gunned down in the street by one of his own customers, and Sheriff John Wayne takes them to the town jail until a traveling judge makes it into town next week for a trial. That would be me, out in the street, leading the lynch mob.
        Some people do not "get" my humor, so get ready for that. These are the people they invented smiley faces for.
        Maybe that will help.
        Anyways thanks for the responses. I'll get some photos uploaded tomorrow. I haven't finished reading them all yet anyways, so things could evolve.
          • 31281
          you should start an air conditioning company in Saudi-Arabia!
          better yet, a HVAC inspection company!!!
          • ngml
            Repair of an LG split AC system indoor unit PCB
            by ngml
            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
            This indicates an error in the communication between the outdoor and the indoor unit.
            The outdoor unit is fine, so the problem is the indoor PCB.
            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
            Does anybody have the schematics of this board,...
            02-01-2025, 12:55 PM
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            09-15-2025, 03:36 AM
          • DrDos
            Unit runs but no speaker output kenwood KR-6030
            by DrDos
            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
            09-14-2025, 09:57 PM
          • nobbnobb1
            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
            by nobbnobb1
            Hi guys,
            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
            02-03-2022, 11:14 AM
          • CDNBrewer
            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
            by CDNBrewer
            Hello Everyone,
            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
            Symptoms:
            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
            • I swapped the Left and Right surround
            08-05-2025, 09:29 PM
