Best Least Expensive Multimeter?
  • Nerfinator
    • Feb 2015
    • 56
    I'm in the market for a new multimeter and I think it's time to spend something closer to $100 rather than the $10 I have been spending on disposable ones that crap out after 6 months to a year and I figure this would be the place to ask as to what would be a good multimeter in that price range? I do mostly small, consumer, electronic repair.
    Thanks in advance!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Best Least Expensive Multimeter?
    Hands down the Fluke 17B+.
    True, you can get higher count meters with more features for the same price, but the Fluke meets its CAT rating.
    • retiredcaps
      • Apr 2010
      • 9271
      See this thread.
      https://www.badcaps.net/forum/showthread.php?t=43396
      --- begin sig file ---
      --- end sig file ---
      • dj8452000
        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
        by dj8452000
        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
        02-18-2025, 08:28 AM
      • trex66
        Craftsman 82345 Multimeter broke!
        by trex66
        My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
        03-04-2025, 04:26 PM
      • Sofian75
        Things not to do with a multimeter?
        by Sofian75
        I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
        I fixed some of them and some I ve made things worse by blowing components.
        Every time while taking measurements with my multimeter.
        Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
        So my question is are there things I should not do with my multimeter?
        Or measurements I should do only with the charger and battery unplugged?...
        06-27-2024, 05:13 AM
      • max_smart
        T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
        by max_smart
        First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
        Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
        06-01-2024, 03:27 PM
      • DrDos
        Wierd reading on my multimeter
        by DrDos
        I'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
        09-12-2025, 04:44 PM
