Substitute for Mosfet AO4423L
  • leggot
    • Oct 2014
    • 50
    I need a replacement for a AO4423L mosfet, because the original part doesn't seem to be readily available?
    Are there any substitute parts that anyone could recommend?
    Datasheet:
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Substitute for Mosfet AO4423L
    http://www.ebay.com/itm/261053644668
    --- begin sig file ---
    --- end sig file ---
    • Longbow
      • Jun 2011
      • 623
      legot, perhaps you could show us a diagram of the circuit, or a description of what the FET does.
      Is it plugged in?
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • Nooy
        VGA MOSfet permanently shorted and loss of MOSfet pad
        by Nooy
        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
        02-14-2024, 02:26 AM
      • edugimeno
        Find substitute for mosfet in servo board of versacamm sp-540v plotter
        by edugimeno
        Hi There!
        I am currently serviciing a plotter versacamm sp-540v
        I found a shorted mosfet labeled J553 which corresponds with SJ-553s (surface mount)
        Neither local stores nor other webpages that are able to provide it before 1 month (only aliexpress, with 1 month delivery) can provide this part
        I need to find a substitute for it. Can anyone give me a hint on a part that I can use to replace it?
        Also, given the schematic Im attaching (pg 36, transsitor Q1) , does it make sense that the whole machine won't turn on when I press the POWER button on the panel? This...
        10-27-2022, 10:46 AM
      • AppleLover123
        Asus X712EA 3 volts after the first mosfet
        by AppleLover123
        Hey guys,
        i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
        I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
        Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
        I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
        Now i thought something...
        12-15-2024, 07:49 AM
      • MicroSMD Lab
        by MicroSMD Lab
        I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
        01-10-2024, 06:36 AM
