Resistor in charging circuit?
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Hey all,
    I picked up one of these 6 volt battery powered cars out of the trash for my boy awhile back.
    Works, but of course the original battery was shot, and I had no easy charger.
    Finally got around to buying a charger and battery, and went sort of 3rd party on it. Matched the battery, and bought a "power wheels" charger on ebay for it all.
    Trying to solder everything up, so I can easily plug in to charge. I pulled the wiring off the old battery, which I assume is original. There is a small resistor in the circuit, but I'm not sure if I should use it , another resistor, or none at all.
    Battery is a 6 volt sealed lead acid 4.5 amp hour
    Charger shows 6 volt DC 7.2 Watts
    Also attached a picture of the wiring with resistor. Thanks for any help!
    • 31007
    Re: Resistor in charging circuit?
    that's a self-resetting poly-fuse.
    use it.
    • tucocaps
      • Apr 2013
      • 331
      • United Stated
      Thanks STJ! Learned something new. I thought it looked like a resistor, so I wasn't sure. I might want to test it as well, because I was able to charge the old battery one time, and it worked for awhile (used a car battery charger). 2nd time, it seemed as if the battery wouldn't take a charge at all.
        • 31007
        i'v never seen one fail, but feel free to meter it.
        when you put it in, dont place it aganst anything that can melt or burn, they get real hot when they trip.
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Petr0x
          Bosch 12V and 18V chargers modification
          by Petr0x
          Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
          You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
          Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
          05-24-2024, 01:00 PM
        • repair-it
          Engineering help - how does the charging circuit on this board work?
          by repair-it
          This board attaches to 2 12v batteries in tandum (Black/Red squares). There is a 24v power supply that attaches at the 2 pin molex connector (circled in red). I need help to determine which components run the charging circuit in an effort to determine a point of failure. There are multiple via's, making it difficult to trace the circuit. Nothing appears to be shorted but I wasn't able to fully test as I do not have 2 12v batteries available. My assumption is that the micro controller (red question mark) determines when to turn the charging circuit on & off. I'm pretty sure a regulator and...
          08-31-2024, 12:32 PM
        • fab13
          Nintendo Switch lite charging chip heats up and does not short circuit
          by fab13
          Hello everyone
          Small technical problem on a Nintendo Switch lite
          Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
          After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
          When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
          Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
          09-16-2023, 04:59 AM
        • flat-earther
          Hoover FM216LI cordless vacuum refuses to charge
          by flat-earther
          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
          06-06-2025, 03:14 AM
