General Question Part Duex: Resistor
  • Michale32086
    • Nov 2011
    • 1453
    Got a bit of a charred power board.. A resistor burned clean thru.. Lightning strike...
    I am not up on basic electronics as High School Electronics was many MANY moons ago..
    Anyone hazard a guess what the value would be???
    Thanx..
  • Michale32086
    • Nov 2011
    • 1453
    Re: General Question Part Duex: Resistor
    Here is an example of some of the other resistors on the board...
    I thought they might provide more info..
    I found this link:
    http://www.michaels-electronics-less...olor-code.html
    but I am not sure how to extrapolate the missing color bands..
    The resistor is right next to the fuse, if that might provide a clue as to it's value...
    • Michale32086
      • Nov 2011
      • 1453
      OK, mea culpa...
      http://www.fixya.com/support/t584749...lew_fuse_r101a
      I'll write 10,000 times on the blackboard:
      GOOGLE IS MY FRIEND
      GOOGLE IS MY FRIEND
      GOOGLE IS MY FRIEND
      GOOGLE IS MY FRIEND
        • 31259
        i doubt that's the only thing wrong,
        whatever that resistor feeds is probably shorted.
        • Michale32086
          • Nov 2011
          • 1453
          Yea, I replaced the resistor, held my breath and powered it up.. The replacement resistor started smoking..
          So, it looks like I am replacing the board...
          Thanx for the reply...
          • G-Sting
            iPad Pro A1876 SHORT Part Identify Help Needed
            by G-Sting
            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
            SO My main concern is what part should i order what should i search the name for ?
            on Ipad...
            05-15-2025, 09:30 AM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
          • artvandalai
            What resistor ohm will work better to repair this waterpik?
            by artvandalai
            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
            01-05-2025, 04:10 PM
            HP Elite Slice G2 + Google Home Hub Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Google Home Hub can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Google Home Hub boardview and Elite Slice G2 + Google Home Hub schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-12-2024, 02:20 PM
