I have a weird situation where I've recapped a board - replacing electrolytics with solids or tantalums. So far, great success. My only hang up is one cap gets uncomfortably hot, so my thought was to use a few lesser capacity caps in parallel to distribute the workload, thus distributing the heat.
The problem is 470uf caps are awkward to replace, at least on digikey I couldn't find too many easy combinations that add up to 470. I did eventually find these for my first configuration 100uf+370uf:
http://www.digikey.com/product-detai...313-ND/4552809
http://www.digikey.com/product-detai...539-ND/3462162
I see one of those is aluminum and one is tantalum, also one of them is rated at 63V and i'm not sure if that's ok in a 16v application.
for my second configuration, 220uf x 2 + 15uf x 2 which I'm much more fond of:
http://www.digikey.com/product-detai...3-1-ND/1973911
http://www.digikey.com/product-detai...9-1-ND/2781413
My concern here is I'm just not sure if there's some weird interaction of using different types of caps in parallel. I'm assuming if you use a 10% tolerance and 20% tolerance cap in parallel, your effective tolerance is 10%. On a dielectric level, do any kinds of caps go insane when put in parallel with others?
