Can someone please help me identify this resistor?
  • R_J
    • 9578
    I don't know which igbt you have, you would need to remove it to see the number, but this Sanken one should be close to show you what is internal
    If the current resistor is blown open, one of the internal igbt will be bad and I would check what motor it drives is not also damaged
    This whole board can be ordered from ali exp, might be cheaper than repairing as these igbt's are not cheap by themselves.
    • lotas
      • Jan 2016
      • 4708
      • Russia
      Originally posted by mitsu2k
      I think I’m understanding now. So likely the IGBT module shorted, causing the current sense resistor to burn. Also this IGBT shorting also may have possibly caused the processor to go out.
      It is possible, but not always, it depends on luck, remove the module, you can use thin nippers to bite off all the legs, then unsolder each remaining leg, check the resistance of the processor power supply, and then test it (here this processor also has its own internal firmware).
      • mitsu2k
        • Aug 2013
        • 219
        Lotas, I removed the current sense resistor. I had assumed it was 100% open because of how badly it was burned but apparently it was not. After removing it, I measured 280 ohms between these pins in the photo as you explained. Is this better news?
        btw, the motor it drives seems ok. I have two of these mini split units so I took the board out of the good unit and put it in the unit that had this bad board, and it seems to be working normal.
        • mitsu2k
          • Aug 2013
          • 219
          Lotas, I want to thank you so much for your kind help. You spent A lot of time with me and spared me a huge headache. I am going to take your suggestion and find one on Ali Express. Thank you again. You are a boss!
          • mitsu2k
            • Aug 2013
            • 219
            Thank you R_J. That datasheet was helpful in getting an idea of how it works.
            • lotas
              • Jan 2016
              • 4708
              • Russia
              #26
              Search by this number, since such a board can have different configurations and different firmware for compressor power.
              • mitsu2k
                • Aug 2013
                • 219
                I could not find anything with those specific numbers. Only the numbers on the PCB itself
                • mitsu2k
                  • Aug 2013
                  • 219
                  The IGBT is fried. Big hole on the underside. Problem is I cannot find a replacement unless I want to get what is likely a fake one from eBay. I have had bad luck with that in the past
                  Also I should mention that I ordered a new board on Aliexpress. After ordering it, The seller wanted me to upload photos of my old board for compatibility confirmation. After doing so, they said that the board I purchased will not work for me. However, they said they had a used board that would work. Well, after waiting 3 days for them to ship, They messaged me this morning saying that I need to cancel the order as the board is not available. So now I'm stuck.
                  • lotas
                    • Jan 2016
                    • 4708
                    • Russia
                    #29
                    https://aliexpress.com/item/1005008810094554.html
                    • mitsu2k
                      • Aug 2013
                      • 219
                      Hi Lotas, would you trust this one from AliExpress?
                      • lotas
                        • Jan 2016
                        • 4708
                        • Russia
                        #31
                        Hi, it's 50/50 luck, I've ordered many times, sometimes I've found used ones, but they work, and the price is not high and the reviews are good, you can take a risk.
                        If you decide to order, don't forget to click on your specific option.
                        • gica69
                          Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                          by gica69
                          I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                          Resistor shows orange range silver gold and green lines.
                          Thanks in adv...
                          07-21-2025, 09:49 PM
                        • jinu_j
                          by jinu_j
                          Hi
                          05-03-2025, 10:51 PM
                        • mikey5791
                          Need help to replace burned resistor in 350w atx psu
                          by mikey5791
                          Hi to all forum members,
                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                          12-26-2024, 04:55 AM
                        • MidnightRoller
                          Can a resistor lose resistance after hot air?
                          by MidnightRoller
                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                          02-02-2022, 11:46 PM
                        • sikocan
                          Identify resistor R802 PS4 Pro PSU
                          by sikocan
                          Hi team, can you help identify value of this resistor. From a PS4 Pro. PCB board model: N300A004L. Location of resistor is R802 as pictured....
                          11-01-2022, 07:33 PM
