Reverse engineering of DoCreate DHJ567 handheld spot welder
  • spleenharvester
    • Mar 2010
    • 913
    Hello everyone
    I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
    Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting the weld probes to sense continuity too, which makes it difficult to use when delay is enabled.
    Hardware: It uses a simple 3.7V pouch cell that is run through a boost converter up to 5V. Four NCE30H29D MOSFETs are used to fire the weld pulse. The MCU is a Cmsemicon CMS8S6990N. Programming pins are exposed but presumably you need Cmsemicon's programmer.
    It's not the best but it's impressive how they have been able to bring it to market so cheaply, and would probably work well in someone's collection if they don't want to splash the cash on a supercapacitor welder.
    DoCreate DHJ567 Spot Welder Schematic V001.pdf
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • Jul 2011
    • 6058
    I have one of these as well but it does not have the screen it has a row of LEDs that you set the welding current by I suspect that the battery cell is shit because it runs down quickly from what I remember and I do not think that it is a high current capacity rated battery cell that is the first problem
    I am going to do a very detailed analysis of this battery cell and see what it really can do at what load and what does the discharge graph curve looks like
    I have to finish some testing that I still working on then I will set up the 40 amp battery testing machine and do a 40 amp load test and see what voltage values I get and for how long but I going to this test outside just in case the battery cell burst into flames I can throw it in the driveway and put out before it gets out of control
    I have to also take some measurements of this pouch battery cell and see if come in a high current capacity battery cell and how much it cost because the high current capacity battery cells are 2 or 3 times the cost of a low current capacity battery cell I am not referring to amp hour rating that speck is different from current capacity
    Because the discharge current / voltage curve looks different from a high current capacity versus a low current capability battery cell and generally speaking the high current capacity battery cells have a lower amp hour rating not always but the cost is considerably higher than a low current capacity battery cell with nearly the same amp hour rating
    On a side note I have a battery operated battery tabbing welder that also has a low current capacity battery pack cells but the high current capacity battery cell is about 5mm wider and will not fit in the enclosure correctly but adding an extra battery cell made a big difference in it performance even though it was still a low current capacity battery cell
    So if a high current battery cell is not going to fit correctly I will just get another low current capacity battery cell and see if the performance is better or not
    Or
    I will just put a much bigger battery pack that I bought from Battery Hookup that is brand new and it has 70 battery cells in parallel which is what I bought it for originally but then I found a different brand of battery operated battery tab welder that also has the same issue about the battery draining very quickly when welding with it ( which I thought I might use in this welder too but it might not not be a good idea or option because the battery tabbing bolt holes are very close to the edge of the circuit board that is the main reason I sighted away from doing this in the first place on this one that is being discussed on in this post the circuit board can be made to support the battery cables and I do not have to worry about the bolt holes breaking into pieces
    I have one very important question to ask you where are the welding connections are on this circuit diagram because I do not see them unless you named it something else just curious about this
    I will post the results here when they are available
    • CapLeaker
      Leaking Member
      • 8295
      I know you using this to spot weld batteries together for a pack. Call me ignorant, but I just solder mine.
      • spleenharvester
        • Mar 2010
        • 913
        It's Weld+ and Weld- at the top right
        Yes a lot of people on Reddit get upset if you do that lol. I don't know how much it really matters in practice, but spot welding is a lot quicker for large packs either way.
        • CapLeaker
          Leaking Member
          • 8295
          A lot quicker? You’d need to almost manufacture or repair batteries a lot to make it worth while. For that one battery pack here or there, I’ll keep soldering.
            • Jul 2011
            • 6058
            I will do this from time to time but keep in mind that if the battery temperature goes to high then the pressure CDI will trip and you would not have any voltage output so use solder that has flux and do not spend much time on the positive end of the battery cell the negative side is little bit more forgiving but a little bit harder to solder you can do it but just keep this in mind when doing this procedure
            • CapLeaker
              Leaking Member
              • 8295
              True. That's why one needs a way soldering hot and fast plus surface preperation... and I got what I need to make that possible. My way takes longer, yes... but I don't make or repair enough battery packs to justify.
              • spleenharvester
                • Mar 2010
                • 913
                I bought mine for building two 10S4P packs - 2 welds * 2 terminals * 40 batteries = 160 welds per pack. It starts to become a faff real quick.
                Plus it's a good investment if you want to build e.g. tool batteries, I broke out the welder again to build a bunch of 5S2P Milwaukee packs.
                • CapLeaker
                  Leaking Member
                  • 8295
                  Yeah… see… I don’t do any amount nor that battery size either. I mean I get it why someone needs to have it. I suppose if I had to do that what you did, I’d look at something like that probably too.
                  • spleenharvester
                    Reverse engineering of 18650 4-channel tester
                    by spleenharvester
                    Hi friends
                    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                    05-04-2025, 02:43 AM
                  • nix30101
                    Thoughts on Reverse Engineering 8FC8 suffix logic..
                    by nix30101
                    Greetings i am in the process of reverse engineering the bios logic for the 8FC8 suffix so far I have found most of the bios functions related to the suffix from a bios dump and I have verified inputs and outputs to test with plus the chartable for the 8FC8 suffix.
                    12-16-2024, 12:50 PM
                    New Super Capacitor 5v DC Battery Spot Welder with a 12 volt power supply
                    by sam_sam_sam
                    This is a new item at Battery Hookup that I bought I have always wanted to buy a good capacitor battery stud welder but they are to expensive for my budget that I want to spend on one this was surprisingly moderate price for what it can
                    It came by FedEx today so I decided to try it out on some tabbing that my battery stud welder has a little issue making constantly welded with out having to redo some because it would not get hot enough to do it properly
                    Well right out the box when the super capacitor charges up with the setting as follows does a very good job the first...
                    05-21-2023, 04:28 PM
                  • spleenharvester
                    DoCreate portable spot welder damaged
                    by spleenharvester
                    Hope someone can help me, this is the second time I have killed one of these and I wasn't able to fix the last one. This is a portable Farad capacitor-based welder: https://www.aliexpress.com/item/1005004682391629.html it has worked very well for me, but the DC jack failed. I replaced the DC jack, but did not wait for the capacitors to discharge, and in the process accidentally shorted the green COM wire (that joins the middle of the capacitors) to the -12V terminal. After that there was a burning smell. Now the machine turns on and runs but the capacitors do not charge up.
                    The only...
                    04-25-2025, 05:04 PM
                    Modifing a Battery Spot Welder because of Controller Issues
                    by sam_sam_sam
                    I keep having the same exact issue with these battery spot welder controller boards
                    They either do one of two things
                    One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
                    Or
                    The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
                    This...
                    10-12-2019, 08:51 AM
