Hello. Does anyone know the code for this regulator marked H50A A121?
Regulatory code marked as H50A
Tags: None
Hola, gracias por tu respuesta. Si es un regulador de 5 V y la distribución de pines coincide, 300 mA son suficientes. Gracias, se acerca bastante.
Google translate - Hi, thanks for your reply. If it's a 5V regulator and the pinout matches, 300mA is sufficient. Thanks, that's pretty close.Comment
Try to identify the ICs that are powered by the regulator, then examine their datasheets. That should tell you what voltage they expect.Comment
Hi. Thanks for your reply. That's the first thing I did; it's also printed on the motherboard. It's 5 volts output, thank you.Comment
by klynstronicHello. Could you help me identify the code for this component marked .11?
It belongs to the BMW X1 automotive gear selector circuit....-
Channel: Common Parts Library - Datasheets
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by Sorrow1Hi,
I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
When I recorded video of POST card and played it in slow... -
by DynaxSCHi Folks
I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works... -
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM - Loading...
