Help with a poorly looking component identification plea
  • Techie_hobby1
    • Feb 2023
    • 49
    • England
    stj and all
    Note: I am extremely novice at producing circuit diagrams at the moment, and trying to get to grips with KiCad, but this is how I think it is wired up....
    I will only like kind replies please.
    REMEBER We all had to start somewhere and with time they will improve.
      • 30977
      not bad.
      i'm not a kicad fan untill they add "rubber banding",
      till then i'll stick with Eagle - the good eagle before AutoDesk fucked with it!
        • 30977
        so the burned part is a resistor to drive the led from mains - ideally with only a couple of mA.
        if the heater doesnt heat then it can only be the switch or thermal cutout - presuming the ptc isnt cracked inside.
        • truclacicr
          • Apr 2019
          • 297
          • australia
          Wow, that's a scary circuit.
          • Techie_hobby1
            • Feb 2023
            • 49
            • England
            stj
            Thank you for your response.
            What is rubber banding?
            Ahh okay, now I understand. I thought the 4.7k ohm resistor was used for current limiting the whole circuit but then that would be crazy, but of course now you explained it a little better I totally understand why this would be a resistor.
            Question.. from my calculations using a 240k resistor to limit the mains current my calculations are as follows (please correct me if I wrong here):
            mains (UK) = 240v
            resistor = 240k ohm (240,000)
            I = V / R
            240
            240,000 = 0.001 mA
            With that in mind Watts is P = I x V
            therefore
            0.001 x 240 = 0.24
            I will replace it with a 240k @ 0.5W resistor to ensure it does not get to toasty, but will probably replace the Diode just to be on the safe side.
              • 30977
              we are both wrong about the resistor calculation
              your wrong because rectified mains is about 340v (240 x 1.41)
              i'm wrong because it's only half-wave rectified - although the peak is the same.
              maybe 330k
              rubber banding is where you can grab a part or trace and move it and it stays connected and just stretches to the new location.
              handy if you start running out of space as you can grab whole chunks of a circuit and move them apart without breaking the interconnections
              • Techie_hobby1
                • Feb 2023
                • 49
                • England
                #27
                stj
                This bit always confuses me.. 340v = rectified mains is this because of the diode (approx) 0.7v on both half cycles?
                Okay I know what you mean by rubber banding now - I just called it footprint dragging haha. KiCAD started to include that feature back in version 8, and it has since been improved with this version 9.
                So which components do I need to remove to make this a little safer. If I just disconnect the 12v DC port does that mean only 1 of the PTC heaters will function... if so I wonder if this will produce enough heat... this will definitely need to be corrected
                  • 30977
                  it only uses 1 ptc at a time.
                  the dc jack is the questionable part.
                  mains is a sinewave, the stated voltage is the average not the peak.
                  • Techie_hobby1
                    • Feb 2023
                    • 49
                    • England
                    #29
                    Oh now I understand.. I thought that the 2 PTC's were connected in Series, but looking back at the schematic they are 2 separate circuits as per your previous mentions
                    Therefore, if I disconnect DC socket, 1 x ptc and the 3.4k resistor that will solve the danger side.
                    Any thoughts on adding some kind of temperature control i.e thermostat to control its temperature a little better.
                      • 30977
                      it will never go hotter, but it can go colder.
                      you need a pwm based temp controller module from aliexpress - if they make one.
                      you could also keep the dc jack but make it safe by seperating it.
                      use a 2pole switch and a second led.
                      • Techie_hobby1
                        • Feb 2023
                        • 49
                        • England
                        #31
                        stj
                        Yes it would be to control temperature to make it a little colder. It does seem to get pretty hot - considering the size of the PTC it is quite impressive at what heat is produced.. so a way to turn the heat down a little bit, ensuring that it does not scold my friend would definitely be a good mod.
                        Would something like this work PWM, Electronic Speed Controller Module - 240v
                          • 30977
                          it's overpriced.
                          and not that good - you ideally want something with a temperature sensor
                          maybe designed to drive a hot-air station?
                          • truclacicr
                            • Apr 2019
                            • 297
                            • australia
                            #33
                            If you decide to eliminate the DC side of the circuit, or separate it, could you use an ordinary incandescent light dimmer switch? It's not ideal, but it's cheap.
                            • Techie_hobby1
                              • Feb 2023
                              • 49
                              • England
                              #34
                              truclacicr
                              I will definitely be eliminating the DC side..
                              I didn't think the incandescent dimmers used PWM? however the LED dimmer modules worked as PWM from memory.. Iactually think I might have a few of those in my spare parts storage, therefore even cheaper still.
                              Surely they would work because they are built for 240v??
                              • truclacicr
                                • Apr 2019
                                • 297
                                • australia
                                #35
                                Incandescent dimmers control a TRIAC by varying the phase angle.
                                https://www.electronics-tutorials.ws...08/power27.gif
                                  • 30977
                                  the problem without feedback is the ptc will ajust itself to fight the dimmer
                                    • Jul 2011
                                    • 6031
                                    To a certain extent this is true however you would have lower heat output overall which would indirectly control temperature plus depending on how much power is being delivered to the heating element it still might not make it linear enough to be practical in the long run
                                    • Techie_hobby1
                                      • Feb 2023
                                      • 49
                                      • England
                                      #38
                                      How about Arduino or something like that. Anyone know if this is possible to overcome the obstacles that keep getting in my way?
                                        • 30977
                                        arduino would still need a triac circuit and a thermocouple
                                        • Techie_hobby1
                                          • Feb 2023
                                          • 49
                                          • England
                                          #40
                                          Would this work?
                                          220V AC TRIAC PID temperature termocouple
                                          • Shulgin
                                            Acer predator XB241YU Component identification
                                            by Shulgin
                                            I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
                                            After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
                                            In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
                                            I...
                                            05-11-2024, 11:06 AM
                                          • thebomb602
                                            ASUS GA402R IC identification
                                            by thebomb602
                                            Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
                                            also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
                                            EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
                                            11-21-2023, 02:30 PM
                                          • Tend0
                                            hp elitebook 840 G4 no 5v IC identification
                                            by Tend0
                                            Hello everythone
                                            i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
                                            i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
                                            05-31-2025, 09:13 PM
                                          • Tomylee
                                            Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
                                            by Tomylee
                                            I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
                                            It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
                                            I'm looking for help with the following:
                                            The exact identification or part number of the T5 component
                                            05-28-2025, 12:42 PM
                                          • FrozenHaxor
                                            SOT23 component identification
                                            by FrozenHaxor
                                            Hello, I have two identical circuits and one has a component with a hole in it, it is some sort of MOSFET driver, as two gates of large MOSFETs are connected to the lower right pin of it, I'd rather avoid guesswork if positive identification is possible.
                                            04-09-2025, 03:17 AM
