Kenwood EEPROM question
  • tibimakai
    • Jan 2012
    • 3680
    First of all, I don't know anything about EEPROMs, or almost nothing.
    I'm buying broken Kenwood double din nav units which they have a common problem, they never completely boot up, just keeps rebooting.
    I have found a shop, which repairs these for a lot cheaper then Kenwood itself.
    But I would like to find out how they do it, because I would like to be able to do it.
    They, seem to replace a nand flash on the PC board.
    The IC is a Toshiba TC58NVG1S3ETAI0 2GB nand flash chip.
    Here is the datasheet:
    What I would like to find out, what this IC does and if it holds the firmware or not?
    I have replaced it with a new one and the receiver doesn't even boot up.
    I'm guessing that it needs to be programmed to be able to boot, am I right?
    If yes, then I would have to load it with the latest firmware?
    The firmware, contains a CAB file, two ROM files and a bin file.
    I was looking for a programmer, but I haven't really found one that works with the same exact part number, but it's pretty close. The programmer is an ELNEC brand, which it's way to expensive for this purpose.
    Any input would be appreciated.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Kenwood EEPROM question
    Here are some pictures, they are not the best. If needed, I can make much better pictures.
    • aweks
      • Nov 2019
      • 8
      • usa
      did you ever find out hiw to program these, im thinking only way it to read a known good one and clone it.
      • tibimakai
        • Jan 2012
        • 3680
        I have managed to repair one. I had to purchase a programmed IC, from kenwoodparts.com, or pacparts has them as well. The IC is around $60.
        You have to ask them, it is not available on their website.
        I believe all that series uses the same nand. DNX6190HD, 6990HD, 9990HD, etc.
        After I have replaced it, it would not boot, but after I have touched the touchscreen, it booted up and it was working fine after that.
        I can't explain what happened with that weird bootup, but I was happy that it did boot up.
        Most likely, that would be the only way to have a good one, other than buying one.
        At the time, I couldn't find a programmer, that would program that Toshiba IC, at a reasonable price.
        • tibimakai
          • Jan 2012
          • 3680
          https://www.pacparts.com/part.cfm?pa...08&mfg=Kenwood
          • aweks
            • Nov 2019
            • 8
            • usa
            thx, i am thinking it is possible to program blank one by using cn902 on the daughter- i/o board, then letting windows connect as storage device, there are some dnn models that run android and people have successfully connected to the flash like this in an attemp to root.
            mine is a dnx571hd with black screen red triangle, i need to do more diagnostic before changing the nand
            • tibimakai
              • Jan 2012
              • 3680
              Somebody helped me once to fix a DNN990, using Putty, but this one is different.
              What I have mentioned earlier, it applies to that series Kenwood. I don't know anything about the 571. Matter of fact, I have one also, with black screen and red triangle LED and I don't know where to start. It seems like a common issue. I see quite a few of them, with this issue on Ebay, with the same issue. It also could be corrupted file on the internal micro sd card. I believe, if you copy the content to a Windows PC, it should show, if there are corrupted files on that card.
              • aweks
                • Nov 2019
                • 8
                • usa
                i took some readings on the nand chip ic500 today, what seemed strange was vcc and vss showed they were shorted, the chip is still on the board so right now i cant be sure if the problem is in the chip or elsewhere on the board, or the possibility it may be normal in its unpowered state. i may need to buy a working unit to play around with, good luck with your 571 ill keep you posted if i make any progresss
                • tibimakai
                  • Jan 2012
                  • 3680
                  It can't be a smd capacitor shorted somewhere on the board?
                  Nothing gets hot?
                  • aweks
                    • Nov 2019
                    • 8
                    • usa
                    i was able to get reading while powered up, even though it looks like short when powered off it does indeed have 3.3v when power is hooked up, called pac parts and ordered ic500 for my model unit, was gonna try to dump the flash before installing but my programmer only support 29f type tsop chips, should know in a week if it will work, hope i didnt waste $70
                    • tibimakai
                      • Jan 2012
                      • 3680
                      It would be nice, if the replacement nand would fix it, but who knows, maybe the MICOM is bad and not the nand.
                      How much it was and how long it takes to get it. Usually you have to wait for them, because they are special order items.
                      • aweks
                        • Nov 2019
                        • 8
                        • usa
                        it was like $70. that is with priority mail, was 57 for part alone, she said it wiuld be 2-3 days for them to get then another 2 to arrive here, hopefully wont take too long, ill keep messing with it in the mean time.
                        • aweks
                          • Nov 2019
                          • 8
                          • usa
                          no good on new nand, swapped daughter card with known working board and unit turns on, must have another problem with that board, possibly ram.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Sorry to hear that. What else is on that board, I don't remember. It could be a missing voltage?
                            • aweks
                              • Nov 2019
                              • 8
                              • usa
                              update, i got it going! cooked the 4 ram chips a little to get a reflow going and it booted up. u may want to try the same for the unit you have.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Great news!!! Good job!!!
                                The Rams are BGA?
                                • aweks
                                  • Nov 2019
                                  • 8
                                  • usa
                                  yes bga, so not easy to swap out
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    These BGAs create so many issues, in so many devices.
                                    It will take some time to do mine, because right now, I'm installing drywall in my garage.
                                    • karlox
                                      Request for EEPROM Firmware Backup – Epson PowerLite S18+
                                      by karlox
                                      I have an Epson PowerLite S18+ projector in the workshop showing signs of a firmware fault. I’ve checked all voltage lines and signal paths, and everything seems within normal range.
                                      Here’s the issue: when the power cable is connected, the power LED immediately turns blue even though the projector doesn’t start. When powered on, the fans run but the lamp never ignites. After a few minutes, both the temperature and lamp indicators turn red.
                                      I’m attaching the backup I read from the IC in case it’s useful for analysis or comparison.
                                      If anyone...
                                      10-16-2025, 07:48 PM
                                    • MF ELETTRONICA
                                      Hitachi 32HB4W56I NAND Firmware
                                      by MF ELETTRONICA
                                      Hi guys, have a nice day. I wanted to ask if anyone has the bin file for this nand MT29F4G08ABAEA. I'm attaching the model of my TV, the motherboard and the panel number. Please, if anyone can help me, thanks.
                                      11-28-2024, 02:35 AM
                                    • duwane
                                      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                                      by duwane
                                      Hi All.
                                      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                                      The issue:
                                      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                                      10-26-2022, 07:02 AM
                                    • tranquility
                                      Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                      by tranquility
                                      i want to repair an Onkyo TX-NR809 receiver.
                                      symptoms:
                                      on power on, display appears and i hear one click. enue functions is given.
                                      - no hdmi output
                                      - audio output not tested, but i think it is not there
                                      - usb sticks are not recognized
                                      if i read out the chips with display+standby button + tone+
                                      both dts show only ????
                                      chip is D830K013BZKB4
                                      things i have done:
                                      - reflow of the dts chip without taking off and reballing
                                      - changed the aluminium caps without the big one with 25v because i dont...
                                      08-25-2025, 01:04 AM
                                    • NSkyLab
                                      Toshiba 55SL417U looking for EEPROM and Firmware
                                      by NSkyLab
                                      Hello everyone, I described the symptoms and measurements here
                                      It seems I tried everything, my last idea is that the eeprom or firmware (or both) may be corrupt.
                                      I'm not able to find eeprom and firmware dumps in open sources.
                                      Hoping someone here has access to closed forums or manufacturer's service center resources and can help get those dumps?
                                      01-20-2023, 12:29 PM
