Charger IC And 3 - 5 v Powersupply.
  • dreico33
    • May 2018
    • 36
    • Bolivia
    Hellow everyone,
    I just have some questions regarding to these IC's. When we are changing 3 -5 V power supply do we need also to change Upper and Lower Mosfet? Or the output Capacitor (No idea which is this cap). The same goes for the Charger Chip. Do we need to change also the Mosfets?
    Thank you very much.
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • Johndill
    Dell Inspiron 7567 LA-D993P odd charger issue
    by Johndill
    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
    Here are the tested scenarios:
    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
    2. With the laptop off, plug in charger (LED says on) & the front charging...
    11-16-2022, 10:55 PM
    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve...
    11-05-2024, 04:43 PM
