Identifying a component
  • YellowJacket
    • Dec 2020
    • 105
    • Slovakia
    Hello friends,
    I have difficulties with finding this component online: "312L", with 'L' letter underscored. Damaged component is from a drone, and It is connected to a motor ( with the upper leg ). Any ideas, what it is? Looks like some N-channel mosfet to me, even by measuring another, working one, it behaves exactly like N-channel mosfet. But I would like to find the exact component, to be sure, what parameters it has. For proper replacement.
    Thank you in advance for any hint.
  • YellowJacket
    • Dec 2020
    • 105
    • Slovakia
    Well, I replaced it for N-channel mosfet from some donor board, with really high maximum drain current, and it works just fine. If this thread can be deleted, you can do it so. Sorry for useless thread.
      • Jul 2011
      • 6057
      This would not be useless if you post the part number that you used this in your repair it would help someone else solve a similar situation
      • redbaron1007
        Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
        by redbaron1007
        I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
        Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
        09-09-2025, 11:10 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • madjid911
        identifying a mosfet for asus laptop
        by madjid911
        HI, I discovered a mosfet in continuity, and grounded the motherboard. I would like to replace it to be able to repair the motherboard of my asus pc. I am not a big expert, can you tell me what is this mosfet?I can't find it on the internet.
        Can you help me find the datasheet and maybe tell me which mosfet I can replace? I have macbook a1466 1708 1278 donor motherboards.
        THANKS...
        08-08-2023, 01:57 PM
      • boardbread
        Identifying MOSFET "03 GUB 7X1V03" or "02 GUA 6X4H06"
        by boardbread
        Hello! I have these MOSFETs used on a desktop motherboard, the name of the motherboard will not be helpful, because it is quite rare and doesn't have schematics. They are used in a power rail and have very unusual metallic package, I've never seen anything like this. Could you help me identifying these, or at least identify their package?
        12-24-2024, 10:26 AM
      • kingis85
        Asus rog flow gz301v mosfet ic identifying
        by kingis85
        Here i have asus rog flow, super powerfull and expensive tablet. The problem is that it only works with a battery. The owner had it plugged on and his dog wanted to put his teeth on the usb-c plug and well.....
        So after that it is not charging with a new asus official charger. I opened and tried to find something burned with microscope but everything looks good. I did not found any short. I did see that it does not try to take any power with usb meter, so the 5v line must be open somewhere. This board is really hard to make any sense because i can not find any kind of data sheet or info....
        11-20-2023, 05:50 AM
