Bench PSU question
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Giving the socket a quick clean and a close look, nothing jumps out at me.
    One other thing, while I remember, is that when the voltage is set to zero, and then the amperage is also set to zero. the voltage goes up to around 5 -6 volts. Not sure if that might be a dodgy pot but a quick test of them shows that the voltage pot goes from 1K down to 1.8 ohms and the amperage pot goes from 10k down to just under 4 ohms.
      • 30965
      check the tracks from end to end in each pot
      • redwire
        • Dec 2010
        • 3902
        Where is the output capacitor? You need at least 10-100uF cap at the regulator's output for stability or it can oscillate. It might be doing that.
        A weakness with this PSU design, and every bench PSU has shortcomings... is the for the output voltage to spike up when you shut off power. You can have it set to 5V and then turn it off or a mains failure happens, and the output voltage spikes up and blows whatever you were powering. It's because the 5V rail falls fast (powering LED panel meters) so the control op-amp can't operate but the pass transistor gets turned on full until the big caps discharge on the HV rail.
        Another possible weakness is charging batteries I would guess 12V is the max. but a 24V battery could backfeed and blow parts if the PSU voltage was set low say a few volts, or power outage - and you connect the battery.
        For reverse-polarity protection I just add a big MR756, 6A10 or 10A10 for good smoke and sparks whenever I do that by accident lol.
        • Crystaleyes
          • Sep 2021
          • 493
          • Brazil
          Think I'm just gonna put in some new ones. I have plenty here...
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            Thank you for the suggestions. I'll give that output capacitor a go and let you know how it goes. If that works and the voltage stabilises, then I'll give the diode a go too.
            Nice one!
            • caspian
              What Zener Diodes on a Linear Power Supply
              by caspian
              Dear members,
              I have a linear variable power supply with unknown brand name that I used for voltage injection.
              Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
              In addition, I discovered that its zener diodes are defective.
              I can replace the burned transistors.
              But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
              Therefore, I cannot replace the zener diodes.
              I do not want to test the zener diodes in a test circuit to discover their model or value.
              no schematics are available...
              05-26-2025, 12:38 PM
            • Eniaro
              Bench test a series X
              by Eniaro
              How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
              06-17-2025, 01:46 PM
            • Fontana
              BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
              by Fontana
              1. g´day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
              2. if
              12-18-2023, 05:45 AM
            • Nikolai Danylchyk
              Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
              by Nikolai Danylchyk
              Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
              Thanks in advance!...
              05-08-2025, 06:18 AM
            • DjKrish
              Zener diodes component equivalents
              by DjKrish
              Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
              1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
              2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
              3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
              These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
              08-15-2021, 11:06 PM
