Solid caps
  • icebytes
    • May 2007
    • 5
    Solid caps
    Now motherboard makers started use them
    Idea is do guide for best Solid caps
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Solid caps
    Well, most boardmakers are shifting away from the well branded and accepted manufacturers like Sanyo in favor of cheaper producers from Taiwan and China.
    I would not be surprised, if those cheaper, unbranded solid caps from Taiwan will again be as problematic as those low esr elketrolytics from Taiwanese producers are in the past up to now.
    The problem is always not only the knowledge, than a consistent quality in the producktion prozess.
    E.g. those solid polymers are very very sensitive to trapped moisture during entcapsulation.
    There is no quicktest, for that.
    So if there is one producer, who missed this due to cheaper raw material, lower cleaning standards or just due to untrained and unaware workers, a long therm failure rate is unavoidavle.
    I personaly would ask for Sanyo solid polymer caps, as those have proven themselve as reliable since ages.
    • starfury1
      • May 2006
      • 1256
      Re: Solid caps
      Think You hit the nail on the head there Gonzo
      not that i know much on who makes what with solids
      if they start using cheap made products trouble is sure to follow
      It been proven on these forums if you use good quality electrolytics a MB or psu can last a very long time.
      So once the bean counters start buying low quality versions of solids then here we go again I suppose.
      Yeah maybe a faq and good/sus/bad thread on solids would be the go
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
      • icebytes
        • May 2007
        • 5
        Re: Solid caps
        so Sanyo solid polymer caps ?
        sounds nice , gonna search where i can bought them on my city , for have them over Bad situations
        • Rainbow
          • Aug 2005
          • 1375
          Re: Solid caps
          Sanyo OSCONs - they're used on server boards and in notebooks.
          • starfury1
            • May 2006
            • 1256
            Re: Solid caps
            These the puppies Here ?
            Yeah a little over the top with my last post but as the old saying goes
            "you get what you pay for"
            • gonzo0815
              • Feb 2006
              • 1600
              Re: Solid caps
              The problem is, that you can`t be shure what caps your are get, wehn buying a new board.
              E.g. Gigabyt is lately using sometimes Sanyo, and sometimes something else on the very same board.
              • starfury1
                • May 2006
                • 1256
                Re: Solid caps
                true, lets hope thats the lessons been learnt with regards to using crap caps but I wouldn't hold my breath on it.
                You would hope its a similar quality cap,
                esp since they are making a big song and dance in regard to using them in their publicity machine....like how much longer they last etc
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: Solid caps
                  It appears that motherboard manufacturers are far more likely to use solid caps now. Especially 2008 and later.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • madscientist750
                    Replacing electrolytic caps by solid caps on old motherboards
                    by madscientist750
                    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                    10-19-2025, 06:10 AM
                    by momaka
                    03-12-2025, 03:42 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • captain150
                    by captain150
                    03-16-2025, 07:34 PM
