Silicone material around buffer chips.
  • n3lka
    • Jan 2014
    • 84
    I'm curious about the cured silicone material I see around most chips and some caps/transistors, mostly on y buffer boards. Does it have heat dissipation properties, or is it for insulation? I'm assuming it's some type of heatsink compound. If it is heatsink material, is it like this stuff I see on ebay?
    http://www.ebay.com/itm/Silicone-The...p2054897.l4275
    I want to see if I can make a good y buffer board for a panasonic I'm working on, and try my hand at new soldering techniques. If I successfully remove a bad chip and replace it with a good one, I want to make sure the it's not going to die from overheating.
    I've never did any work with this new medium, and would like to try it out.
    Thanks,
    Brian
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Silicone material around buffer chips.
    Probably glue used to hold parts on the board before they are soldered in place. The stuff that turns yellowish/brown can become conductive as it ages.
    • n3lka
      • Jan 2014
      • 84
      I'll upload a picture when I get a chance. This stuff encapsulates the entire chip on the edges.
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • ugamazing
        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
        by ugamazing
        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
        08-31-2022, 07:34 AM
      • piernov
        NVidia bumpgate
        by piernov
        Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
        Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
        May complete this post at a later date with more details.
        Basically issue is a combination of thermal dissipation of the chip with hotspot,...
        03-27-2021, 10:34 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
