I can't find this pinout anywhere? Anyone know where to find it?
S1WB S60 pinout?
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by staviHi There,
I'd like to read/write the contents of the chip. This is a 1995 vintage FORD ECU and IMMO controller.
Unfortunately, I can't find a circuit diagram or pinout on the chips.
The serial number uniqe, not factory?
Can you help me identify the chips or pins?
many thanks!
hi, Stavi... -
by staviHi There,
I'd like to read/write the contents of the eeprom chip.
This is located on the print head of a Canon inkjet printer.
It is likely that this disables the head after printing an xy copy.
Unfortunately, I can't identify the chip, so I can't read it either.
That is written on it: TO2 (T null? 2), KU
Does anyone have any idea what this could be?
Many thanks for help... -
by pickledeggHello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...10-02-2024, 04:54 PM -
by corrizeHello, I search this connector (oxydated).
It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
Do you know how to find this connector please ? What is the exact name for find it ?
... - Loading...
