Question about electricity
  • matk
    • Oct 2023
    • 7
    Hello, I have a question about electricity. Suppose I'm well insulated from ground and neutral, and the live wire of mains comes in touch with a wound in my finger, will this potential interfere with body voltages, hearth for example, or it will only go to its circuit return path ?
    Thanks!
    • 31267
    you will feel it - if thats what your asking - your body is an antenna to ground through the air.
    now if you where in africa or arizona during the summer with very dry air it will be less.
    but in european humidity your gonna feel it and i can tell you from multiple experiences that 230v with hit hard!
    • matk
      • Oct 2023
      • 7
      The question is can electricity go through return paths that don't belong to its circuit ?
      For example if your body is completely insulated from air, ground, neutral, etc. of that circuit and the live wire comes in contact with an open wound, will the 230v potential interfere with the many potential difference that are in the body or it will not ?
        • 31267
        if your in a vacume and therefore already dead then it will not do anything,
        but as i said - air is a resistive return path to ground.
        thats why lightning discharges static to the ground - the air conducts.
        maybe watch this?
        https://www.youtube.com/user/msadaghd/videos
        https://www.youtube.com/user/bigclivedotcom/videos
        specially
        https://www.youtube.com/watch?v=wR6g38Pxwog
        https://www.youtube.com/watch?v=-5R-KBa18ME
        • Ihandyrepair
          • Sep 2017
          • 44
          You should ask yourself,
          is worth the risk to work on live wires?
          just remember accident can happen
          i did in the past where I replaced light switches without turning the breaker off
          just one switch 2 wires right? Why not
          i know I was saving few minutes
          but then I realize I am taking a risk where the live wire could touch the metal frame or something making short or me accidentally zap myself
          I look this way
          if I am 100% I can do it safely then I might try
          like only 1 switch, plastic box
          if it is more than 1 switch in the box
          then no
          too many risk
          • redwire
            • 3912
            It's best to not rely on your body being "completely insulated". That is a myth. And who works with only one hand?
            I saw a low power Tesla coil running, sparks and streamers arcing over to a person who is "completely isolated" - they are off the floor on a plastic platform. This is not DC but low current high frequency AC with the high voltage causing air to break down, this is what an arc is.
            Seems all OK, just fun right?
            The HV arc to the guy from the TC also jumped from him to the mains power transformer and he got electrocuted.
            Once air is breaking down in an arc, it is low resistance so he got mains across him arm-arm despite being on a insulated platform and the HV being low current. The arc acted like a wire.
            • plummmm
              Asus X570-P identifying potential missing SMD
              by plummmm
              I am trying to identify a potential missing component from an Asus X570-P motherboard. I could not find a boardview for that exact motherboard, but I did find one for the X570-Pro here https://www.badcaps.net/forum/troubl...prime-x570-pro
              The component missing on my board I believe is a small 3 pin device above the Nuvoton Super IO. The X570-Pro uses a similar Nuvoton and there's a similar looking SMD just...
              08-29-2025, 11:57 AM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • loko
              Tesla 13.7 body sculpt repair problem, need help with finding the thyristor marking.
              by loko
              Hello everyone.
              I have a device that is used to shape the human body muscels and burns fat. Works on the principle of electromagnetic impulses. One thyristor in side is shorted which has only this unknown mark on it ( QC230301 ). I can't find any information about it anywhere on the Internet. I tried to replace that thyristor with one of 1.6kv 800A and after 5min. of work he has burned out again, which means that he is probably weak. There is no schematic diagram on the internet, but that didn't suprise me because all the transistors and chips that are on the boards have their markings...
              10-27-2024, 11:31 AM
            • dennis_elx33
              NO BODY MARKING Diode
              by dennis_elx33
              Hello Everyone,
              I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
              While compared to the reading of another diode from the next channel it won't read at reverse bias.
              Now the problem is; it does not have any body marking.
              So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
              What do you think is this diode?
              Can you please suggest what part number can i use to replace this faulty diode instead?
              Hoping that you...
              06-14-2024, 12:36 AM
            • Acnologia
              BIOS Unlock potential - T540p ?
              by Acnologia
              Hello to all,
              I have in my hands a T540p , that i would like to unlock the full pottential of the bios , such as hidden options and wifi whitelist etc.
              Which of the 2 chips should i dump ?
              Thank you....
              09-23-2025, 03:00 AM
