How to diagnose little step down and power management BGA chips never shorted
  • corrize
    • Apr 2021
    • 272
    • France
    I have different sort of those little BGA chips (step down DC-DC, power management battery, …) I replaced 10 on differents mobile devices (no schematics) but I noticed often they can be dead but never shorted. I see some signs : burn marks, resistance drop by comparison with good board (40 KOhms to 1 KOhms for example)… but not easy to be sure of the diagnose. Because I can't access on all tracks (balls) with the meter.
    Sometime, I know only after replacing chips.
    Do you have tips for diagnose please ?
    • Jul 2011
    • 6039
    Please post some pictures of the front and back of the boards so we can see what you are dealing and talk about
    • corrize
      • Apr 2021
      • 272
      • France
      Here it's a simple board, DC-DC down convertor so the chip is easy to find as guilty in this case because the other components are easy to check, but this chip is never shorted. I have this one, and in 4 or 5 dead boards : no short. Even if the chip is physicaly broken. It's harder/not possible to diagnose when that sort of chip is on other big board.
      The most of the time, I can't diagnose with power on because the boards are inside box with cables. Sometime, I diagnose like this : if no voltages out of this chip and no short, so chip dead... Because I never saw those ones shorted. But it's not reliable, the chip could be not enabled because something else is faulty.
      In diode mode, I can't find a big obvious differences. In resistance mode, I can see differences but on big board, I can't be sure.
      (I have no thermal camera).
        • Jul 2011
        • 6039
        Try doing it in diode mode instead ohms mode it might reveal more results
        I had posted on another post about this topic before
        Do the same exact testing in the diode mode on your meter and compare them this way
        Here is a video that explain exactly how to it this way and why she thinks it better for troubleshooting boards
        https://www.youtube.com/watch?v=pRpyHF2dfq0
        I have tried this method once briefly and it I think it doable but it more time consuming
        This is if you have two exactly the same boards​
        I hope this helps one note the video is a little bit long but if you have the patience she does explain why she thinks it’s better than using ohms mode on your meter when comparing values from one board to another board this might be helpful to you trying troubleshooting this device
        • ugamazing
          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
          by ugamazing
          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
          08-31-2022, 07:34 AM
        • Prott
          [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
          by Prott
          Hello dear badcappers!
          The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
          Backstory:
          After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
          If there is a way to narrow down which memory module is faulty it would make my life much...
          06-03-2024, 12:05 PM
        • Yanleb
          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
          by Yanleb
          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
          D608, good
          D618 RF101L4S, good (See warning 1 below)
          D619 RF101L4S, good (See warning 1 below)
          D865 RF101L4S, shorted (See warning 1 below)
          IC464 Inverter HA MC74HC1G14, shorted...
          03-09-2020, 12:00 AM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
        • feherhollo
          WSON8 NEW Bios Chips READ, ERROR, ETC.
          by feherhollo
          I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
          I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
          For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
          11-26-2023, 09:33 AM
