History of wirewound resistor
+ More Options
Posts
  • socketa
    A Shorted wirewound resistor?
    by socketa
    This resistor is from an ATX APFC PSU that connects bridge rectifier negative to primary capacitor negative
    I think that it's a current sensing resistor for the APFC
    Is it correct that it's color code indicates that it should be 0.47 ohms?
    I measured it to be around 0.08 oms
    The PSU blew up (visible arc flash) after problems with a powerstrip, but i got it working now after replacing the 10A fuse, rectifier, etc and removing/shorting the APFC diode locations and using a jumper in place of this PFC current sensing resistor
    I don't think that APFC likes being connected...
    05-15-2022, 04:50 PM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mikey5791
    by mikey5791
    Hi to all forum members,
    12-26-2024, 04:55 AM
  • MidnightRoller
    Can a resistor lose resistance after hot air?
    by MidnightRoller
    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
    02-02-2022, 11:46 PM
  • artvandalai
    What resistor ohm will work better to repair this waterpik?
    by artvandalai
    The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
    01-05-2025, 04:10 PM
