Wavetek 130 Output issues
  • technodruid
    • Apr 2024
    First post!
    Last night I finally got a chance to try out a wavetek 130 that I purchased a year ago or so after finally getting unpacked from a move. It was working really well, I was testing the various settings from the 50 ohm output into my rigol scope and it seemed to be fairly accurate. I was stepping through the course adjust from x10 to x100 and sweeping the dial looking for any distortions or drops/rises in amplitude. It all looked great.
    Then when i switched to the 1M setting, the sine wave disappeared. I moved back to x100k and the sine wave was still gone. Something got messed up when I switched to the 1M setting.
    Today I was trying to see if I could get any signal at all, and found that for settings x10 to x100k I can get "a signal" between 0.8 and 1.0 on the fine adjust dial, for sine, triangle, and square. However, each waveform has it's own issues.
    Broad description of behaviours
    • All have a DC offset where they did not before (-0.3V sine, -1.2V triangle, 5V square)
    • No discernible output for any amplitude or any range on the 1M setting for any of the three waveforms
    • Sine and triangle now output as a reversed shark fin and reversed sawtooth respectively
    • Sine is the only waveform that matches the peak-to-peak voltage dial setting, at 10V half way. Triangle is about double the amplitude at 20V half way, square is about 200mV half way
    • no visual indications of blown or damaged parts
    • Power supply is absolutely fine
    • DC offset dial works
    • have not checked sync, nor would I know how at this point.
    I have a google doc started where I have begun to log my measurements here.
    I am hoping it's just an issue with the opamps? I only have a very poor quality manual scan on hand so troubleshooting from what I have is very slow and difficult.
    Cheers.
  • redwire
    • Dec 2010
    • 3912
    Welcome to the forum
    Somewhat common to blow a signal generator's output stage. See if Q39, Q40 are OK, any smoked resistors. If you short the output or connect to something inductive like a transformer, they can get blown.
    If OK, then check the power supply rails, the +/-15V regulators at TP2,3 and +/-6V as well TP5, 6 which powers SYNC OUT. Is that signal OK?
    It's getting old, so the electrolytic capacitors are likely dried out. There's only 8: Six Sprague 100uF 16V, and two 1,000uF 35V, I just replace them all it's less hassle.
    Otherwise I think you'd need to go inside it with a scope. The main oscillator IC4/5 CA3030 should work at 1MHz scale but you can check at TP7 to see if that is the problem - or if (downstream) the sine/tri shapers or output amplifier crap out. It's a bit weird everything stopped working right.
    These are useful gear because they have a strong output, to 40Vpp. Later models added protection diodes and a fuse to the output.
    Manual & schematic http://www.bitsavers.org/test_equipm.../130_Aug72.pdf
    • technodruid
      • Apr 2024
      Thanks for the tips redwire!
      These appear to be ok. I do have some replacements on hand, I swapped them out and checked the forward voltages across their pins, everything looked nominal. Ran with the replacements, same issue. No smoked resisters that I can tell.
      All caps were swapped out. They were all outside 20% out of circuit. ESR was a little high too. Signal is a little cleaner, but still "half" a signal.
      +/-15V looks good. Tuned it in, as it was close to out of spec wrt details in the manual. No change to output.
      +/-6V looks ok. Could be better. TP6 shows a slightly larger voltage difference at 6.3.
      Sync out has NO squarewave. It only shows ~5V DC.
      HOWEVER: While testing TP7 for voltage and then through my scope, the sync signal appeared. It was bang on with the dials. Also, TP7 appeared as a triangle wave with the same frequency. I didn't check the P-P voltages before the signal disappeared. I had swung the course selection around to 10, 100, and so on and swept the fine tune dial. The sync was working great. I switched over to 100k and the sync went dead. It did not recover after power off, or after disconnecting and reconnecting the test points as I had when it started running. After the sync pulse disappeared, the triangle at TP7 went back to the original faulted pattern I was seeing on the 50ohm output: Triangle on the falling edge, square on the rising edge. I take it the main square generator, or maybe some components associated with either the 100K or 1M setting (or both) may be at fault?
      CA 3030's look good. Their output pins show what I see on the output. I also checked the diodes around the triangle wave section since the maintenance section of the manual mentioned them. They all had an expected voltage drop, nothing out of the ordinary.
      • technodruid
        • Apr 2024
        Perhaps there's an issue with the CA3036?
        • redwire
          • Dec 2010
          • 3912
          Take a plastic pen and gently tap things, the PC board etc. to find if that aggravates the signal coming and going. It sounds like you've got a loose connection? Maybe an oxidized IC socket or switch like SW1. I use DeOxit on them.
          The master oscillator "integrator" I would get working consistently first at TP7. When it croaks stops osc., take voltage measurements on the CA3030 and CA3036. That will tell us what's going on.
            • 31214
            ah yes, old ic sockets.
            i just spent yesterday replacing about 60 of them from about 1980
            i also have a scope with bad (loose) transistor sockets - dont trust those either.
            one other thing, if you mix god and tin or silver and tin, you get tarnish.
            • redwire
              • Dec 2010
              • 3912
              IC5 for the oscillator is CA3030 DIP-14(!) single op-amp, an older part. It would be replaced by the '741 but that is in a DIP-8.
              Not sure what IC4 CA3036 transistor array is doing, it could be to lower the input bias current but a '741 already achieved that compared to the CA3030, or temperature compensation.
              One cal trimpot could be looked at, R28 looks like an offset (not for frequency).
Name:	integrator section.png
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
                Corsair CX750M [Model 75-002019] - burned output toroid inductor
                by momaka
                Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                09-19-2021, 08:44 PM
              • CoppellTVRepair
                Troubleshooting PFC with SPC1012T not raising output
                by CoppellTVRepair
                It has been a long while since I posted here to ask anything....hope you can help.
                I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                03-09-2025, 10:38 PM
              • flibidy
                Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                by flibidy
                I have here a Magnum IA.100 which belongs to my parents.
                The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                What Ive done........
                01-01-2025, 01:26 PM
