"conversation" aka need an answer from kiriakos gr
  • philliesfan30m
    • Aug 2013
    • 542
    since you always have an answer for everything tell me why this would happen! i need help from a professional tech that comes on this site but never helps anyone. so now is your chance! show me how intelligent you are and how stupid i am by explaining this to me. i don't wanna hear anything about anyone else that posted just the answer since that is what you consider a "conversation"! i don't want your opinion JUST AN ANSWER since that is what you consider a conversation anyways! so it should only have a question and answer in a conversation "according to you"! so i provided the question now you answer my conversation! prove yourself!
    https://www.badcaps.net/forum/showth...hlight=spectre
    I need an answer to how to amplify my WiFi signal because it is so weak outside
    I have a really bad situation right with a very weak WiFi signal outside of the house and I have been told that I can not have two routers on my modem because it cause issues so what is the solution for this issue
    I can fix the garage door opener with a cat5 cable to device modem or at least that is what I call it and it works very well so far but by doing this I have no router in the garage and no WiFi signal inside the garage unless the door is open but it is extremely weak if not at all
    The MyQ cameras can NOT hookup to a cell phone hotspot I have tried it need...
    11-19-2023, 06:23 PM
  • TraJikar Mac
    [HELP] G712LWS BIOS capsule
    by TraJikar Mac
    I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
    The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
    You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
    Also, I uploaded a backup file for the bios that I extracted by using CH341A...
    06-11-2025, 01:35 PM
  • lostone
    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
    by lostone
    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
    05-19-2024, 11:40 AM
  • karimreza2
    Cq 42 135-tu( da0ax3mb6c0 rev:c) Uma conversation
    by karimreza2
    My laptop ampere 0.900 but no display. PLTRST also ok. NB & SB board. If i plug in ram ampere no change ampere same. Help me
    08-27-2019, 10:20 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
