Could you run a 3 phase motor using Arduino?
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    If you connected in the control wiring onto an inverter could an arduino programmer be used as the controller?
    In my (limited and attempting to learn mind) using the right set of code and some simple wiring this would be relatively simple to achieve??
    Yes?? Or if not can someone tell me why please 🙂
    Thanks 👍🏻
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    3 Phase motors are AC Motors that are either an induction motor (also known as an asynchronous motor) or a synchronous motor. These motors are designed to run on the three-phase alternating current (AC) power used in many industrial applications. AC electricity changes direction from negative to positive and back many times a second.
    there are 2 and 4 pole ones .
    please tell us which motor are you thinking of ?
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      Thanks for your input Pete. I should have perhaps stated I’m an electrician so not a total novice with regards to motors. What I’m not sure about is how Arduino works. Trying to learn about it though.
      But in my mind, if Arduino is capable of producing/utilising up to 30v DC, running a VSD should be sufficient to run either a 2 or 4 pole?
      One having less or more torque than the other surely isn’t the main consideration?
        • 31204
        arduino and other microcontrollers turn individual pins between 5v / 3.3v and ground - usually with a limit of 25mA at most
        you would use it to drive a few H-bridge circuits.
        there are already 3phase invertor circuits online - i'v seen them.
        • Donny2derby
          • Apr 2023
          • 228
          • Uk
          H bridge circuits…. Talk to me Goose! Do you mean half bridge rectifiers or amplifiers?
          Surely its limitation of 25mA isn’t that much of a concern? It’s the DC voltage I need for the VSD that I need to concentrate on isn’t it?
          • petehall347
            • Jan 2015
            • 4440
            • United Kingdom
            https://www.modularcircuits.com/blog...es-the-basics/
            • Donny2derby
              • Apr 2023
              • 228
              • Uk
              That’s a very interesting read Pete thanks. Some of it a bit beyond my understanding at present but I can take the theme from it.
              • sbt123
                charnwood w821 mini wood lathe motor problem
                by sbt123
                hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                10-27-2024, 03:43 AM
              • Per Hansson
                Motor run capacitor physical size vs voltage rating & measurements?
                by Per Hansson
                (TL;DR skip the first paragraph)
                I encountered my first dead motor run capacitor at a customer this week.
                For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                (Unless a servo motor makes more sense that is).
                But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                The pump would run but sometimes trip the 10A breaker.
                I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                Then it could...
                09-20-2020, 06:32 AM
              • mikey5791
                Help identify this motor
                by mikey5791
                Hi all forum members,
                Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                Correct me if i am wrong on the initial test.
                Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                11-24-2023, 07:54 PM
              • SavaBogdan
                Help disabling a vcore phase on a MSI X570 Carbon - I have schematics + boardview
                by SavaBogdan
                Hello.
                Does anyone have any experience with disabling a power phase on the CPU vrm?
                The controller is IR35201 6+2 phases. It only uses 5 phases and the pins for pwm and feedback on the 6'th phase are not populated (no traces).
                I got the board with a burned mosfet which I removed along with a part of the pcb. I dremelled away the short as best I could and the board started up fine without the vrm heatsink.
                I then put some sealant and left it for two days to completely dry. I suspect the pressure from the thermal pads on the heatsink compressed the layers so when I started...
                10-21-2022, 10:05 AM
              • G0RIT
                Reebok one GT40s treadmill lift motor runs at switch on
                by G0RIT
                Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
                06-23-2022, 05:57 PM
