Charging a 12v 72ah car battery with a PSU
  • Darren Hibbert
    • 116
    Hi.
    Hope I'm in the right section.
    I have a discharged 12v 72ah sealed car battery and want to charge it up full. I don't have a car battery charger but have a bench power supply 0-20A 0-30v.
    What should I set on the LED display? I believe about 14.5v but what about the amps?
    • 31278
    14.8v
    amps depends on how long you want to wait.
    and how thick the wires are
    dont forget if you charge it you need to allow for hydrogen-release - so dont do it in a closed space or near sparks/fire
    • petehall347
      • Jan 2015
      • 4448
      battery will take what it takes amps wise .it should drop as it charges it if its a good battery . you can go up to about 16v but nor recommended really .old cars often went that high . 13.8v will charge it . 14.4v will charge it a bit more .
        • Jul 2011
        • 6070
        It depends on how low on charge this battery is and how long it has been in this discharge state
        if its very low voltage and it has been in this state for a long time more than a week
        I would recommend that you slow charge it set your voltage at 14.5 and your current for about 5 amps until you voltage goes above 12 volts and then you might be able to go to 10 or maybe higher as long as your current does not go down and your voltage does go up drastically if the voltage goes drastically turn your current down and let it charge longer at 5 amps
        One note if you have very high voltage from the beginning trying to charge the battery it might not be very good anymore
        Another note do not leave it charging with this voltage for a long time if your current is below 3 amps because you can have a situation where you might be boiling the liquid out of the battery cells a safer voltage might be 13.8 volts and a current less than a amp or less concerned it fully charged now weather or not it pass a load test is another story
        I hope this helps you with your battery issues
        • petehall347
          • Jan 2015
          • 4448
          if battery is still good the voltage should come back up in short order like seconds to a few minutes . if its well discharged it might take a week or so before it charges fully . if so never let it discharge again as it will likely kill it .been there done that enough times . if its relatively new and hasn't been frozen whilst discharged it should come back to life .
          • redwire
            • Dec 2010
            • 3912
            any bench power supplies get damaged charging batteries. Especially those chinese ones.
            Anytime you get backfeed from the car battery back into the PSU, it kills it. They can even catch fire and burn up. I have seen it happen if you power off/mains fail while charging. Or if the PSU voltage is far below the battery voltage like a few V and you then connect the PSU to the battery, it can damage pass transistors, IC's etc. in linear PSU's.
            I would recommend using an inline fuse and series-diode if you are really not sure about the PSU being ok "charging". But check its user manual. Most will say if it's OK for charging batteries or not.
            If the battery is old or was totally drained, it needs extra care. It could be sulphated. You can't charge it hard and fast.
            AGM most makes is 14.40-14.70V bulk charge, float 13.50V and temp compensation -5.00mV/°C/cell. Max. current is 10% of C20 or 7.2A here.
            Roughly, I would set the PSU to 14.40V and current-limit to 3-7A or less if the battery needs reconditioning. Leave if for several hours and see what charging current drops down to.
            Here are smart charger algorithms, which are basically what people here like me will advise.
Name:	smart battery charging.jpg
            • Darren Hibbert
              • 116
              Excellent answers. Thank you very much.
              The battery is only one year old and has only been discharged for 24 hours. Ideally I'd like to put it on a 14 hour charge overnight.
              • redwire
                • Dec 2010
                • 3912
                If it's only been dead 1 day I would charge at low current until terminal voltage comes up past 12.0V try a few amps.
                It will take more than 14 hours to recharge unless you are over 6A.
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Julian Bailey
                  HP ProBook 445 G8 Battery not charging
                  by Julian Bailey
                  Hi all
                  We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                  The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                  I have gone around the board with a MM and cant find anything
                  Windows shows the battery fine,...
                  10-11-2024, 10:34 AM
                • piernov
                  Laptop battery charging circuit
                  by piernov
                  1. Some theory
                  1.1. Introduction
                  Almost every laptop has a charging circuit of some sort, that does a few things:
                  • Manages switching between AC adapter and battery power
                  • Manages battery charging and generates power rail to charge battery
                  There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                  • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                  • Narrow VDC (NVDC)
                  Texas instrument has a nice overview of these technologies with some more details at https:...
                  11-15-2020, 01:31 PM
                • kodox
                  ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                  by kodox
                  since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                  the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                  what i've done:
                  - flashing...
                  12-29-2024, 02:49 AM
                • Shinju
                  Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                  by Shinju
                  Hey All!
                  Long time forum member here with a problematic laptop issue!
                  I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                  The laptop would not power on with the new battery installed without the power supply being plugged in.
                  When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                  TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                  10-20-2021, 04:58 PM
