Covering SMD LEDs with bluetac
  • spleenharvester
    • Mar 2010
    • 913
    So I bought a Dell E-port, and the LEDs are annoying as hell (who needs a fluorescent blue eject button?)
    Got it open now and intend to cover the LEDs with bluetac.
    They're just small SMD leds but will doing this insulation cause them to overheat/short out?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • Snav
    • Jan 2014
    • 6
    Re: Covering SMD LEDs with bluetac
    Not unless they are so overdriven they would burn out anyway. Use a removable covering so you can change your mind.
    • Pipolups
      Corsair K70 LUX RGB dying LEDs
      by Pipolups
      Hi there !
      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
      10-08-2024, 11:58 AM
    • THE GTC
      Insignia NS-37D20SNA14 intermittent LEDs
      by THE GTC
      So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
      When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
      11-03-2020, 02:40 AM
    • Ariu
      BMW M-ASK PL2 blackscreen, no radio,  no Reaktion of DVD eject button!
      by Ariu
      I have a device (BMW CCC Unit), which no longer posts anything also blackscreen.
      The unit is getting power, dvd player is spinning but does not eject the DVD when eject Button is being pressed.
      Everything seems to be normal on the board ( no short), except „OASIS xs8805b0aq chip „, it is getting hot when the board is turned on.
      Does anyone has the datasheet or pinout diagram of that specific IC?
      Thanks.
      06-04-2025, 07:58 AM
    • VitalComputing
      Replacing Mode Indicator LEDs
      by VitalComputing
      I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
      I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
      I thought I could just put a resistor...
      09-17-2023, 04:43 PM
    • jimbofz
      just a quick question do all qled leds appear blue when fault finding ?
      by jimbofz
      i have replaced many leds strips that have changed blue when they are worn
      and the new replacements are perfect white
      but when fault finding do quantum leds always look blue?
      08-28-2024, 06:51 AM
