Diode GO C 40
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Diode GO C 40
    Hi
    I need to replace a defective diode in a power supply. the diode's code is GOC 30 or GOC 40.
    I haven't found any details about this diode, anyone can help me on this? the code is first line GO or G0, second line C third line 40
    Thanks for your help
  • lotas
    • Jan 2016
    • 4809
    • Russia
    Originally posted by Eleways
    Hi
    Which diode, in which housing, post a photo of it.
    • Eleways
      • Oct 2014
      • 62
      • Italy
      This one
        • 31265
        are there more?
        if you can check the voltdrop and it's under 200mV then it's probably a schottky rectifier
        • Dvsr
          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
          by Dvsr
          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
          After replacing the caps I started testing out the speaker. It seemed...
          09-10-2025, 10:20 AM
        • caspian
          What Zener Diodes on a Linear Power Supply
          by caspian
          Dear members,
          I have a linear variable power supply with unknown brand name that I used for voltage injection.
          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
          In addition, I discovered that its zener diodes are defective.
          I can replace the burned transistors.
          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
          Therefore, I cannot replace the zener diodes.
          I do not want to test the zener diodes in a test circuit to discover their model or value.
          no schematics are available...
          05-26-2025, 12:38 PM
        • Srdjan01
          Oral-B IO Series 6
          by Srdjan01
          Hi everybody.
          I'm trying to fix this toothbrush that doesn't wanna start. And I need your help.
          Just to inform you that I'm supperbeginner
          First photos are from internet because I did not took a photo of whole board.
          I have noticed that fuse marked with "E" near the battery pole is bad and decided to short it with a "proper calibrated wire" as one would say.
          Now, when I apply 1V from the power supply, limited to 500mA, one of the component stick out from the rosin mist. CHC N2AB (or some variation of that letters) is the hottest...
          03-05-2025, 10:05 AM
        • asr
          Finding replacement diode iPad Pro 3rd gen A1701
          by asr
          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
          07-09-2024, 06:24 PM
        • magneh
          Behringer Eurolive B205D repair - help identifying transistor
          by magneh
          Hello
          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
          Still, I need to replace this transistor....
          06-18-2025, 02:34 AM
