Christmas Light Power Supply Question
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
    Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just find any approximately 30V DC power supply and use that instead, but I'm wondering if that actually works. How does the power supply communicate to the LEDs which effect to use? I tried to use my multi-meter but the battery is dead and I don't have any other 9V batteries so I can't tell what it's doing.
    Thanks for any input.
    Edit: I went on Amazon and there are "steady on" versions of these power adapters but they have this note: "This item only with steady on mode, it is only replace for 30V 0.4A led transformer with steady on, it can't replace for 30V 0.4A led transformer with 8 lighting mode with multiple settings. If your original transformer is multiple settings, please go to our store and choose a right multiple settings one to replace it."
    And there are reviews stating that people tried to replace their 8-mode one with the steady-only one and it caused only every other LED to light up. So confused!
    • 31087
    check big clive on utube.
    he's opened a few of those - one had an eeprom to save the settings
    they are multiplexed and you need AC to light all of them
      • 31087
      https://yt.artemislena.eu/watch?v=ajnw_b8FBRU
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        That link to the YouTube video was broken, should have been this one it seems: https://www.youtube.com/watch?v=ajnw_b8FBRU
        Anyway, I did watch it and determined that I'm still lost and confused haha.
        Are you saying I should find a 30V AC power adapter instead of a 30V DC power supply and it will do what I want with the solid on? Then again searching for 30V AC power supply on Amazon or eBay seems like a lost cause because they are all 30V DC output.
        Thank you!
          • Jul 2011
          • 6045
          See if can find a 36 volt transformer and take a few secondary winding off of it to make it 30 volts ac transform but make sure that it has two separate winding that are separate from each other it is a lot easier to deal with
            • 31087
            use a 24v ac transformer - or 28v
            or open your psu and see if it has a space for the 24c02 eeprom to hold the settings
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Thanks, I'll see what I can come up with.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                OK, I ended up buying one of these, and it works OK: https://www.ebay.com/itm/355009768127
                Only thing is it has a slight flicker to it. It's not obvious - only out of the corner of my eye vs if I look directly at it, and I think it's simply the 60Hz of it all, but it didn't have this flicker with the original power supply being on "solid on" mode. What did they do differently in there to make it not flicker? Is it because it's only 24V instead of the 29V the original one was?
                  • 31087
                  the original supply probably switched it much faster - probably KHz range
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Gotcha. Guess it is what it is. Thanks.
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • burntonnerings
                      Acer K272HUL blue power light but black screen, power supply is ok
                      by burntonnerings
                      Have had two Acer K272HUL monitors die with the same symptoms:
                      - Blue power light is illuminated while the monitor is plugged in
                      - Black screen (no splash screen, etc.)
                      - Power button doesn't do anything
                      Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                      Power supply voltages are fine.
                      There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                      Anyone have any ideas?...
                      12-09-2023, 10:22 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
