Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
  • chth96
    • Nov 2022
    • 118
    • indonesia
    I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
    Since then, This AC/DC adaptor have been out of order.
    But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
    After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
    And Is there any possibility that it will suddenly explode as well as to be out of order again?
    • 31055
    the resistor is intended to act as a fuse,
    the fact that it failed and the psu still works is strange.
    maybe it was under-rated
    • redwire
      • 3910
      OP why did you replace this resistor? Hint: it was not the part that was burning and smelling...
      It looks like 0.1Ω which needs a few amps to heat up!
      Your post does not make any sense.
      So I would say yes it will blow up and back to Aliexpress order another one.
      • chth96
        • Nov 2022
        • 118
        • indonesia
        Although,I have nearly no knowledge about repairing electronic,
        Just like what stj said,I also think that this 0.5 watt resistor maybe act like a fuse,and decisively I noticed that the last black band on surface of 0.5 watt resistor have been damaged.
        You can confirm damaged black band from attached file(0.5 watt resistor) which I uploaded yesterday.
        Of course,There is no resistor or other components which has any damage on their surface.
        By the way,When I have to replace any act like fuse resistor, Should I replace this resistor with other one which have same watt as well as same ohm value?
        • chth96
          • Nov 2022
          • 118
          • indonesia
          when It failed and smelled burnning, I noticed that one pin of 220v male plug have been not fixed,but It swayed from side to side whenever I shaked it. So I fixed it with epoxy glue.​
            • 31055
            use a fuseable resistor - sometimes described as a flameproof or safety resistor.
            they are gray
            a regular resistor with catch fire and burn the pcb!
            • chth96
              • Nov 2022
              • 118
              • indonesia
              they are gray
              Do it means that I should desolder 1 watt resistor(1ohm) from adaptor's pcb and look for flameproof resistor instead of normal carbon resistor like what I soldered on the pcb?
                • 31055
                yes,
                if that one blows it will create a big mess
                • redwire
                  • 3910
                  OP, this is a cheap USB charger.
                  It should have the right fusing to prevent house fire.
                  It should have a good transformer to prevent electrocution. (is this what is burning?) Check the isolation resistance between pri-sec.
                  It should have a TL431 IC for precise 5V regulation. Here it has a zener diode so the 5V will not be accurate.
                  I expect the bridge rectifier to just pop if anything goes wrong.
                  Still not making sense why the resistor cooked but nothing else is. Unless the prongs inside shorted to the board?
                  • chth96
                    • Nov 2022
                    • 118
                    • indonesia
                    Thank you very much for reply!
                    I measured all of resistor on the pcb.
                    You can confirm all ohm value of resistor from the below attachment.
                    I think that ohm value of all resistor seems to be correct.
                    and I found that pcb has CSC7203,MB10M,TWS 817C 217 ic components. It seems that Burnt resistor and mb10m bridge rectifier was soldered next to wire of 220v male plug.
                    Is it necessary to check that mb10m bridge rectifier was broke or not?
                    And How can I check mb10m bridge rectifier if it was out of order?
                    • chth96
                      • Nov 2022
                      • 118
                      • indonesia
                      I just noticed that Its current is very weak.
                      Whenever I use ampere app in any android phone which is connected to this AC/DC adaptor,It shows 150ma at most, While It shows 800-1200ma whenever I connect it to other AC/DC adaptor.
                      It must show more than 1000ma in ampere app, because It is written 5V 2A output on its cover,But It only shows 150ma!
                      I assume that some IC component is out of order and it hinders to supply sufficient current for output.
                      EDIT:I confirmed that the blue resistor(1 watt,1 ohm) ,which I replaced with, is a flame proof resistor.
                        • 31055
                        https://yt.artemislena.eu/playlist?l...vjBw_J7X_X5OnU
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          its a cheap crap power supply that can not do what is says on the sticker . . i got burned with one .reported it to trading standards but they didnt do anything
                          • redwire
                            • 3910
                            I say this charger does not have a TL431 so it has poor voltage regulation and is too cheap.
                            People buy $600 smartphones and then want to use a $2 chinese charger that can be a fake, it has defective output. I hope the transformer windings will not kill someone.
                            So the fusible resistor popped due to a short-circuit between the board and the mains input wiring? Or did this junk ever work?
                            Check for an open diode in the MB10 bridge rectifier, there are 4 diodes inside to test. But these parts usually burn up or explode if they see an overload. So I wonder if this cheap charger ever really worked.
                            • chth96
                              • Nov 2022
                              • 118
                              • indonesia
                              I checked MB10M with LCR-T4,You can confirm all of results from the below attachment.
                              As Hioki Card Hi Tester 3240 is the only multimeter currently I have ,It is impossible for me to check it with reverse polar test for diode.
                              • redwire
                                • 3910
                                The bridge rectifier tests looks OK. Low HV bus voltage only if a diode inside is open. If a diode inside shorts the whole bridge blows up.
                                You had smoke and sparks so it's hard to tell what is damaged. Is it 5.0V but just weak, collapses with small load? What is the output voltage now.
                                I would make sure C2 is good. Make sure the transformer core is not broken, cracked or glue came apart.
                                Otherwise I would suspect the transformer primary windings are cooked due to the short or maybe the IC is bad.
                                But for the $25 of your life you waste trying to fix it, maybe just buy something new?
                                • chth96
                                  • Nov 2022
                                  • 118
                                  • indonesia
                                  I tried to measure voltage of transformer by placing test lead of multimeter on soldering point of transformer.
                                  In order to measure voltage which came from 220v plug and flow into transformer, I pluged this AC/DC adaptor in power strips and I set multimeter to AC voltage mode and placed black and red lead on the point where I draw black and red arrow in the attachment picture.
                                  But as soon as I placed black and red lead,I saw strong sparks and shrapnel of CSC7203 pop up and it brushed past my eyes and hit my hair.
                                  Since then, whenever I touched some soldering point in the bottom of PCB, I felt strong electronic shocks..
                                  So I dispose of this chinese AC/DC adaptor,But Now I am worried that it is safe to keep using power strips in which I pluged blown up AC/DC adaptor.
                                    • 31055
                                    lol
                                    you cant use a voltmeter on the transformer - it's driven at 20-60KHz with about 340v
                                    • petehall347
                                      • Jan 2015
                                      • 4427
                                      • United Kingdom
                                      • unimatrix93
                                        Which resistor should I remove/replace to decrease current to backlight leds?
                                        by unimatrix93
                                        Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
                                        However I need some help identifying the resistor I need to replace to achieve this.
                                        Thank you!
                                        11-29-2024, 05:05 AM
                                      • mikey5791
                                        Need help to replace burned resistor in 350w atx psu
                                        by mikey5791
                                        Hi to all forum members,
                                        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                        12-26-2024, 04:55 AM
                                      • MidnightRoller
                                        Can a resistor lose resistance after hot air?
                                        by MidnightRoller
                                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                        02-02-2022, 11:46 PM
                                        HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                        09-06-2024, 08:50 AM
                                      • flat-earther
                                        Hoover FM216LI cordless vacuum refuses to charge
                                        by flat-earther
                                        I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                        I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                        5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                        So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                        06-06-2025, 03:14 AM
