Stupid novice question about capacitors
  • Mark
    • Feb 2007
    Hi there,
    I just bought a new PCI USB 2.0 card and after examining it, it looks like
    the outer sheath (plastic wrapper?) on one of the capacitors has a tiny
    hole in it, exposing a little of the metal underneath. Is this something I
    should be concerned about (should I return the card?), or is it just a
    cosmetic issue?
    Thanks!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Stupid novice question about capacitors
    plastic wrapper is cosmetic yes
    • Mark
      • Feb 2007
      That's great news, I was worried that it might affect insulation or something.
      Thanks for your help!
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        After all of...
        07-13-2024, 08:14 PM
      • Ady2017
        Are there any datasheets available for Elna RJG capacitors?
        by Ady2017
        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
        05-25-2025, 02:19 PM
      • ctroxtell
        Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
        by ctroxtell
        I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
        01-03-2025, 08:57 PM
