Effects of High ESR
  • capamatic
    • Apr 2006
    • 33
    Effects of High ESR
    My electronics background is fairly good, but I wonder if you can clarify something for me.
    A failing electrolytic capacitor will cause operational failure, complete or partial, in its particular circuit. In relation to a capacitor whose ESR is too great, how exactly will this increased resistance cause failure of the circuit. It clearly will limit the current, but what effect would this have on the circuit. Is the reduced current the primary reason for circuit failure ? What other effects will high ESR have ?
    Many thanks.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Effects of High ESR
    In a PSU/VRM, it will probably increase the ripple voltage, causing the peaks to go dangerously high and causing circuits that depend on regulated voltage to fail. This is most commonly seen with CPUs, Northbridges and Hard drives.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Another effect will be that the voltage will dip out of regulation with a large, fast increase in load. You get a large (I)(R) drop when the current is coming from the cap(s) and the regulator hasn't yet responded.
      PeteS in CA
      • gonzo0815
        • Feb 2006
        • 1600
        ...and then the regulator will overshoot. Another concern is, that the caps will getting hot as the high currents flowing over it. Thus it degrade faster.
        In most cases, the ripple will just makes the singals diminishing into noise, wich makes the system slower if it can correct transmision data, or it will running foobar if the signals are too distorted.
        • bgavin
          • Jan 2007
          • 1355
          Here is a good PSU article on ESR and the Intel VRM spec
          • CapLeaker
            Crimping CAT7 connectors high failure rates
            by CapLeaker
            I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
            Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
            11-09-2024, 04:11 PM
          • Durenth
            DC detection circuit failure on Subwoofer
            by Durenth
            First of all sorry for my English and for my poor knowledge in transistor behavior, I'll do my best to be clear…
            I have a problem with the DC detection circuit of a Panasonic 40W Subwoofer, model SW-P270.
            The relay in the DC detection circuit never turns on thought there is no DC in the audio output signal.
            Output signal is ok, controlled with an oscilloscope.
            I found the service manual (full board schematic attached to this post) and measured the voltage as shown below, pink is the expected value indicated in the manual, red...
            11-27-2020, 10:17 AM
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • CDNBrewer
            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
            by CDNBrewer
            Hello Everyone,
            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
            Symptoms:
            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
            • I swapped the Left and Right surround
            08-05-2025, 09:29 PM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
