dim-bulb like tester. need feedback
+ More Options
Posts
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    first off yes it will kill electronics ignore that, thats on purpose.
    it will be used on a 20 amp dedicated circuit with a max of maybe 2kw for ballasts when killing things and when testing things it will have 3 100 watt lamps. when testing, the ground switch will always be ON but when killing things it will be OFF after all we dont want what im killing to take out the RCD. the bypass switch is for testing once im confident the device is safe and for the initial killing of things then its switched to ballasts to finish it off. feedback anybody? btw its under GNU licensing..
    Follow the white rabbit.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: dim-bulb like tester. need feedback
    TC there is still something wrong with the forum it says my files uploaded but they didnt show up.
    heres the files
    • redwire
      • 3912
      uh, what is this?
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        ^ heres what it normally is mine is sort of like whats in the quote above but you can use heaters as ballasts instead of bulbs, it has a switch to connect the equipment to be tested directly to line, and has a ground disconnect for the device that is under testing. basicly its so i can test antique equipment that pulls more than 100 watts.
        https://www.badcaps.net/forum/showth...im+bulb+tester
        im trying to reverse engineer whats in that thread but with bigger ballast capabilities.
        • bacelery
          • Aug 2013
          I am not very clear about the topic
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            heres what its use is http://antiqueradio.org/dimbulb.htm i created a version of that but with 5-20R standerd 20 amp socket insted of E26 Edison screw bass light bulb sockets so i can use say a 1.5kw heater as a ballast instead of a 100watt lightbulb.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Ballast bank? Use separate 100W lamps, say 5, and use say 3 250W lamps each on a switch for an adjustable ballast.
              OH WAIT ... I forgot! You can't buy 100W or 250W lamps anymore, since they are illegal!
              Muh-soggy-knee
              • redwire
                • 3912
                Okay, so it's a device for current limiting mains-powered stuff, originally using a 100W light bulb (~1A) but you want to use 1.5kW (~12.5A) heating elements for the series resistance. 1.5kW will still make sparks and flames though...
                It's like a poor man's variac, but I have limited success with these, because many loads (amplifiers, SMPS etc.) have a high inrush current until the main filter caps are charged. So it's 10A for a second or two, then 0.5A resting. In the end, you aren't lowering the applied voltage.
                Looking at your schematic for "the killer", I don't recommend lifting ground to the load-under-test. If you have a 12.5A ground fault, you'd see it with an ohmmeter beforehand - and the load will zap you.
                Why is the resistance in series with Neutral, not Hot? Also, you can use an SPST switch and just short the resistance to bypass it.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  A variac is NOT for current limiting actually, many folks get this wrong. It is a variable output voltage transformer. Short out the output, which you set to, say, 30vac, and the transformer will quickly overheat and either cut-out, smoke, or smoke and catch fire. Bye bye expensive variac!
                  I agree with all your points there! It's real stuff this is, and making a mistake might cost you an arm, leg, or YOUR LIFE! :O
                  LOL wtf bbq, you copywrited it too xD
                  Muh-soggy-knee
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    the resistance is through the HOT (red line), and the 1.5kw will only be used when doing this as will the ground disconect.
                    • redwire
                      • 3912
                      Ahhh the video explains all! Used for destroying stuff connected to the mains! FUN
                      I just let the circuit breaker do the work, but I could see nuisance trips so some limiting is needed. I've used old heaters, stove heating elements etc. as 10R 1kW resistors. Your design looks good, I would add an indicator light or something so you know if power is there or the load died
                      I still do not recommend lifting ground, in the video it's a metal bench surrounded by metal stuff and who knows where the ground path is. Microwave oven transformers can make several kV so that bench and surrounding stuff IMHO could get energized. Too dangerous for me, holding a camera and leaning on something and zap.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        I think letting the CB do the job is a bad idea, because it will wear the breaker out, and excessive stress is put on the wiring too!
                        I think you should put a lamp that is ON when the load is OFF.
                        Here is why:
                        With the lamp turned ON when the load is ON, say, the lamp burns out. It is easy to assume that there is a problem and the load is 'not' getting power. You'd get a nasty, surprise shock, or death!
                        If the lamp is set up so it is ON when the load is OFF, and the lamp burns out, you will think the load is still on, and you won't go touching it.
                        Muh-soggy-knee
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          what ground? Edd doesn't have his bench grounded when he did this, hence why he didn't come near touching the table or anything near it with power connected.
                          there is a revision 6 that will be posted around the evening, but for now school time for me....
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            ok here it is! nice indicator bulbs and all..
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              You will want a current limiting resistor for the neon bulbs, they typically run at 90 or so volts, and if you try to increase the voltage further, they will draw a lot of current and get very hot.
                              Use an 82K ohm 1/2 watt resistor (for 120 VAC)
                              If you use neon indicator lamp assemblies, they usually have a resistor built in.
                              Muh-soggy-knee
                              • PeteS in CA
                                • Aug 2005
                                • 3581
                                • USA, Unsure of Planet
                                Can Dim-Bulb Testers be installed at the doorways to polling places?
                                That's not the kind of dim bulb you meant? Ohhhhhhh ........ never mind.
                                PeteS in CA
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  like this?
                                  • redwire
                                    • 3912
                                    That looks great, the indicators are just to avoid confusion when the smoke stops
                                    I remember trying to destroy an alkaline D battery and all that happened was the breaker kept tripping and the nomex wiring rattling in the walls. The energy meter sure would spin up fa$t. Should have used a "tester" like this.
                                    Here's a typical circuit-breaker trip curve (Eaton Cutler Hammer). It shows you can get a lot of current, too much under some circumstances from a 15A breaker.
                                    • goontron
                                      5000!
                                      • Dec 2011
                                      • 4108
                                      • US
                                      ok now rev9.
                                      i added a relay to connect ground past the bypass if the power mains go and i added a mains switch aswell as a mains connected indicator.
                                      • redwire
                                        • 3912
                                        I don't see the need for the ground-lift relay. If mains fails, I don't know of a load that can then generate power into a ground fault, and zap someone.
                                        • Lifeisfun
                                          Trying to troubleshoot DDR4 SODIMM slot with slot tester
                                          by Lifeisfun
                                          Hi folks!
                                          I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                                          Eventually I discovered that it was related to moving the laptop.
                                          Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                                          If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                                          I removed the board got one of those memory slot testers...
                                          06-04-2025, 02:26 PM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                          FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                                          by sam_sam_sam
                                          https://www.ebay.com/itm/405035016711
                                          I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                                          I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                                          04-13-2025, 08:17 PM
                                        • grss1982
                                          PSU killing components?
                                          by grss1982
                                          Hi everyone! Been a while!
                                          So I have a CM MWE 750 Bronze - V2 PSU powering the following:
                                          Ryzen 5 3400G
                                          Gigabyte B450 Auorus Motherboard
                                          32GB DDR4-3600 (2x16)
                                          ASUS TUF 1660 TI 6GB DDR6
                                          1TB NVME
                                          This was purchased by a friend about 3 years ago for her kid and now it showing signs of instability. The PC had this problem of the screen becoming garbled after it was booted up and idling in Windows. It also sometimes gets a BSOD. So I did some stress test by starting with Prime 95 and noticed that the torture test just fails and stops immediately....
                                          01-17-2025, 04:12 AM
                                          Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
                                          by sam_sam_sam
                                          When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
                                          This switching power supply was really fun to recap the quality of the board was very good...
                                          02-25-2024, 08:55 PM
