3D glasses
  • nwflight
    • Aug 2013
    • 56
    3D glasses
    Going to get some for my Panasonic TC-P50ST30 before it dies again.
    Are the aftermarket glasses ok? Considerably lower $ than brand name.
  • kotel studios
    Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
    by kotel studios
    Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
    State I got it in:
    Squealing from the PSU
    After logo I get a blank screen
    After 10 seconds of having a blank display w/ backlight the TV dies
    Give it 7-10ish seconds again and it starts to bootloop.
    What I did so far:
    Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
    Checked all voltage rails:
    5VSB - 4.8V
    AMP+13V - 14.4V
    13V - 12.98V (in manual 12V)...
    09-21-2025, 02:00 AM
  • Yeti
    Asus zenbook duo UX481F wont recognise aftermarket batteries.
    by Yeti
    Hi, the OEM battery stopped working, so i bought an aftermarket replacement, but the laptop doesn't reconise it, says 0% in windows. laptop flashes orange charge light. I have tried 2 different brands and still the same. I borrowed another OEM battery and it worked fine, so i don't think its the motherboard. Struggling to find an OEM battery for it. any suggestions to try?
    03-02-2023, 04:13 AM
  • brconta
    MacBook A1502 EMC 2835 820-4924-A dies when installing firmware update
    by brconta
    I have a macbook Early 2015 A1502 EMC 2835 820-4924-A.
    Whenever I try to update the system the device dies after reboot. It only comes back to life if the battery is disconnected, and then connected again (energy drain). Apparently the firmware update fails.
    I can install High Sierra normally, but I can't install a newer one.
    I can use a disk with a newer system that was installed on another machine.
    I've already tested another chip and another bios file, but no effect.
    Boot ROM: MBP121.0177.B00
    SMC: 2.28f7
    I've tried the procedure...
    11-02-2021, 04:47 PM
  • kotel studios
    Compaq series PDP-124P PSU - dies after a split second
    by kotel studios
    Hi
    I am quite baffled at this PSU that came out from an dead HP d530 (asus P4SD). Tested all the common failed components, all are fine. D2/3 are both fine. Not shorted in any way. Recapped the whole 5VSB board and the PSU came "back" from the dead (earlier there was a short from neutral to earth, went away disassembly). Now even with 5 load HDD's it's still turning off after a split second. All diodes seem to be fine. Caps are OST, which IMO rarely die. There is 3.3v on PS_ON and 5V on 5VSB. Removed most of the glue there was (pictures don't show it). The traces that look...
    12-19-2024, 01:15 PM
  • fiveseventy
    RX570 dies completely, then recovers.
    by fiveseventy
    Hello all,
    I have a Sapphire Radeon RX 570 Pulse ITX 4GB (single fan) which has started misbehaving recently.
    The card was bought used maybe 5 years ago and has worked without issue until recently.
    I have no reason to believe it has been worked on or physically damaged.
    For periods of time it will be 100% perfect.
    Perfect temperatures, no glitches or artefacts, solid FPS.
    I can game, run benchmarks, do whatever without any problem.
    I can reboot the machine as many times as I like and nothing changes
    however, most times...
    06-22-2024, 05:29 AM
