Scanner light bar - harmufull or not?
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Hi everybody,
    I recently had a chance to get rid of some older HP printer/copier/scanner device. Therefore i have kept some parts like scanner light bar (i assume it is fluorescent light bar), few borads with components, 2 motors and 2 stepper motors.
    After i removed scanner light bar and its inverter, i noticed some strange things.
    1) The light source is strong when i look at it. It definitely gives me an unpleasant feeling in my eyes like if I was staring at something very bright. But if i try to light my room with it it is not so strong anymore. For close up lighting it is very good.
    What is it that is hurting my eyes? Is it the whiteness, the brightness, the wrong wavelength? Is it worth trying to find a filter for it?
    2) I just checked the output of inverter for curiosity.. Set my DMM to 600V AC, but no luck in there - just as i touch one of the terminals of transformer output with the lead of dmm it gives a constant little spark there of some frequency and the light goes of while i touch and it is sparking there
    It is easier with light bulb disconnected, it is not as sparky anymore, but i can't see any voltage with my dmm. is shows 0,2V form time to time but that is it. Why is it behaving like that? Is my dmm way too stupid for this frequency? I have no idea what voltage i am playing with but i am sure it might bite my finger a bit if i touch it.
    3) The voltage i am feeding the inverter with is 15V but it works on as low as 4,3V (haven't tried less) with less of the bar glowing. I gave it 15V because what is what i measured on the input of the inverter while the scanner was still somewhat functional. It was jumping between 12-17V, so i gave it the average value. What voltage should i run it normally? It has a 25V lytic cap on the input, so it should be not more than that.
    It says 94-0V on the inverter. So is it the voltage i am working with??
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Scanner light bar - harmufull or not?
    The voltage when the tube is not conducting will be around 1000 volts at 30 kHz or something like that.
    DMM are not designed to measure voltage like that especially at that frequency.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      not harmful just has very high surface brightness.
      i make emergency/closet/outhouse/ect lights for solar homes with them.free from any broken office in a box junker.most are 12v.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        you are overdriving the inverter, standard voltage is 12v but running it at 15v for testing wont kill it. just dont have it ta 15v forever.
        Follow the white rabbit.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          I agree, run it at 12v.
          DUDE! I wonder if you have destroyed your meter. They are NOT meant to measure a few thousand volts!
          Muh-soggy-knee
          • domas
            News Hater
            • May 2013
            • 323
            • Denmark
            ok, thanks for answers. I ran it from crappy power supply so on load the voltage would drop to 12.something volts anyway. But it was funny as while the scanner was somewhat functional the voltage would go as high as 17.something volts before the inverter for a moment, than drop down to 12-13. I will run it from 12V form now on anyway!
            Regarding the dmm those are really rigid for this kind of abuse, and mine is fused. Or it was just me that was lucky with it? 'cause it happens that i push it to the limits once in a while But again, if i knew it was 1000s of volts at 30khz freq i wouldn't have tested it like that. It has a limit of 600V AC.
            Any ideas how to convert it to a nice workshop light? I mean what kind of filter to make it more pleasant for the eyes?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              just place it where it cannot be looked at directly in ordinary use.
              not a lot of lumens but fine for task lights and things like closets,outhouse,ect.
              also note they need to warm up.might be nice for the nighttime outhouse run so your eyes adjust.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Outhouse?! Your a century behind bro!
                You can put a diffuser over the light too, so the light will be not as bright when you look at it.
                Muh-soggy-knee
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  many solar installs are way off the beaten path and away from any utilities.this includes sewer service!
                  • japlytic
                    • Oct 2005
                    • 2086
                    My HP 7400 scanner has some sunburn on the lid from the light bar being on in the same position for some time.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      It's the plastic yellowing due to UV light.
                      Muh-soggy-knee
                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                        by sam_sam_sam
                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                        I also have back when Light of America had these light bulbs available for yard lights
                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                        While the Lithonia lighting fixture has all most certain bulb failure
                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                        I have only had this light fixture for not more than a year if it...
                        07-02-2023, 03:45 PM
                        LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 03:40 AM
                        LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 09:10 PM
                        09-06-2024, 08:40 PM
                      • serious_electron
                        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                        by serious_electron
                        Hello Everyone!
                        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                        06-28-2025, 02:57 PM
