Eprom Clip
  • signup
    • May 2013
    • 189
    Eprom Clip
    Hi
    Just a quick question anyone got/use an eeprom clip like this
    http://www.ebay.co.uk/itm/US-EEprom-...item20cff75243
    any feedback on the product would be good
    Cheers
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Re: Eprom Clip
    Yes I got one of a similar type, had a few problems making good contact with the chip as just a little solder on the chips legs will make the clip not grabbing the chip perfectly.
    Sometimes found it easier to just lift the chip off the board....
    • signup
      • May 2013
      • 189
      Re: Eprom Clip
      Thank you...think that this quote alone answers my qustion
      Cheers
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • dmccul2698
        Pioneer DEX-P99rs "No EEProm " diagnostic code.
        by dmccul2698
        Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
        1). Understand the schematic and check the connections between the EEProm and DSP
        2). Check the functionality of the EEProm
        I don't know if this is the unit's problem but it's a place to start.
        I have little to no electronic experience...
        04-08-2024, 05:32 PM
      • Delicieuxz
        I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
        by Delicieuxz
        I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
        Here's an audio clip of the sound coming from my speakers:
        https://vocaroo.com/16HaryHwTx78
        I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
        11-15-2023, 09:50 PM
      • edgarmg15
        Damaged EEPROM on TV Vizio E320-A0
        by edgarmg15
        Hi everyone
        I´m trying to repair a TV Vizio E320-A0 that I found in the street
        The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
        The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
        So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
        11-19-2022, 03:46 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
