When I find the correct schematic and boardview file for mobo is there some specific software needed to buy to search for components? I use mac and believe this Landrex I see works only on windows. Do I just find the schematic and boardview file and open ? I can't find any info on this. Also do you need both the schematic and .brd file?
how to view boardview .brd files what are they??
Tags: None
by makinenHello,
MB: Acer GH4FZ LA-L202P Rev 1.0
Model no: Acer Swift SFX14-41G
My laptop has random shutdown during use no matter high or low loading since a year ago, but still can be restarted. One day, it got very hot at the bottom near the power chip (PUB1) during use, and finally shutdown when in use and cannot switch on again (like dead), so I suppose there is no major failures and power issue should be fixable.
There is no visual burnt or component damage, I tracked the power rail that the power seems blocked at charger chip (PUB1), measured some resistors...-
by wasylHi, did not found here so uploading to help...
Channel: Schematics and Boardviews
09-15-2025, 07:40 AM -
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by Dr TechnoHi Guys,
I need a motherboard schematic for file for a AORUS 15P XC please. The EXACT motherboard is ga-rx5lxc rev2.0. It currently has a black screen issue and doesn't display to external display but boots into windows and can also display externally when running ubuntu. If anyone has a motherboard schematic file and boardview for this laptop it would be greatly appreciated. Thanks in advance!-
05-01-2025, 01:45 PM -
by nicole77Looking for Boardview file for Xbox One S, Series S and also Series X, Please01-15-2025, 04:50 AM
- Loading...
