polaroid 704 tablet backlight and power issues
+ More Options
Posts
  • cadillacman
    • Feb 2011
    • 524
    A friend gave me this to tinker with. WHen powered on, works fine for a few minuites, then the backlight starts to blink off and back on,.. first slowly and over time more in succession untill it flashes rapidly, then shuts off. At that point the tablet is totally dead and wont even connect to a pc via the usb port. Let it cool down, same deal works untill its warmed up. It will talk to a usb port when first powered on. I did notice one section with tiny transistors or ldos gets extremely hot, i guess i need to get some pics and post but these components are TINYYYYYYYyyyyyy..
    Does anyone know where the heck i can buy a new or used mobo for this thing?
    or maybe i just need to try to fix it... who knows. THis is all new to me im used to changing caps etc.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: polaroid 704 tablet backlight and power issues
    Since this is a tablet, I am guessing the backlight is led, right? If so, my guess is a bad led!
    Could we have some pics, and point out the very hot transistor(s)?
    Muh-soggy-knee
    • cadiman
      • Mar 2010
      • 397
      I have worked on every tablet made just about, but not a polaroid.
      All of the led tablets backlight runs on 5 to 12voltdc.
      I have never had one fail.
      I use them to backlight pumpkins, doll houses and school projects.
      I use the batteries for hobby projects.
      Sounds like you have a battery issue more than a backlight problem.
      These smaller tablets do have battery charging issues and should use a switching power supply.
      I had to buy special glasses to work on these.
      • cadillacman
        • Feb 2011
        • 524
        once i figure out how in the heck to get pics this small, i will post some.
        • cadiman
          • Mar 2010
          • 397
          I have worked on all the coby and toshiba entry level tablets for all the small kids to beat up on.
          They have all moved up to Apple so I fix all of that stuff now.
          More money to be made and parts are abundant too.
          It`s all Dr. Shepard...Brain surgery...not always 100% outcome.
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • CaptainBucko
            Acer ER320HQ backlight issues
            by CaptainBucko
            I have two Acer ER320HQ monitors. Both have dark background (I presume backlight issues) in on the left and right hand sides of the screen. Otherwise image is clear. Can these be repaired? The monitor is supplied externally with 19v DC and I have confirmed that supply is good and stable. Any further thoughts or pointers?...
            12-18-2024, 06:09 PM
          • PJK65
            ASUS Q502LA LED Screen/Backlight Issues
            by PJK65
            Hello Everyone.
            Glad to be a member here! I am pretty new to working on laptops. I was hoping I was going to able to fix this one, but I am having some problems...
            This laptop works perfectly with a HDMI monitor hooked up to it. Here in lies the problem. No backlight! So i figured, replace the screen/backlight assembly. Then I had very dim video (could be seen with a flashlight) but still no backlight. Found after doing some homework that it had a blown ferrite bead, which I replaced. Like an idiot, I forgot to unplug the battery, and when I was hooking back up the 30 pin cable,...
            02-24-2023, 04:47 PM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
