ecu connector repair
  • mohammadsahand
    • Mar 2013
    • iran
    hello
    could any one help me to remove a pin from meganII cem (injector ecu) connector
    thanks
  • mohammadsahand
    • Mar 2013
    • iran
    Re: ecu connector repair
    http://s24.postimage.org/ed4iiw4n9/2..._11_24_26e.jpg
    http://s22.postimage.org/mnu01prox/2..._11_25_57e.jpg
    http://s2.postimage.org/u21os3e6h/20..._11_25_07e.jpg
    • Evil Lurker
      Warranty Voider
      • Feb 2011
      • 454
      Well, typically most connector pins are stamped out from sheet metal, folded and pressed into shape, and crimped on the end of a wire with some god awful expensive tool (hand crimpers can be $300-600 a pair). How the pins are retained in their respective sockets/plugs is there is usually one or more tabs that were pressed out the same time the pin was stamped. Pin goes in hole, tabs stick out, tabs grab sidewalls of hole, pin is stuck. The only way to get them out is to use a special tool that you can slip in between the outside of the pin and the wall of the hole its in.
      Fortunately they are easy to make out a bit of spring steel. Yeah thats right you just got to about use spring steel to make one. I made mine out of the wire clip that holds a motherboard northbridge heatsink in place. I was gonna take a picture of what mine looks like, but basically the idea is to put a 90 degree bend on one end of it about the width of your finger so you can get ahold of it for inserting (ok more like force) it into the pin hole. On the business end you will need to make a slight bend downwards and then take a grinder, either a bench grinder or dremel tool, and carefully grind the spring wire flat to the depth needed to reach the retention tab leaving the bend you made intact. Be careful you don't heat it up too much, otherwise your tool will lose its temper and won't work worth a damn. The best way to visualize it is if you were to take a hypodermic needle and put like a 10 or 15 degree outward bend on just the angled point part (which that might work too). The idear is when you slip it in, the "tool" will make itself flat, but as soon as it reaches the tab the droop will want to spring back down pushing the little metal retention tab towards the inside of the pin where it will stay. Then you can just pull the wire out like its nothing.
      Actually after googling check out the HTA tool in the background of this pic... thats how you want to make your wire look.
      • WoodButcher
        • May 2012
        • 37
        I don't know if pc tools will work for that plug but here is a source.
        http://www.performance-pcs.com/catal...ducts_id=36094
        That's the kit I use for PC repair,
        http://www.performance-pcs.com/catal...ath=60_143_272
        The page it is found on w/ more crimps and extractors. If you need to purchase from them Performance PC's is an ok bunch. I've done business with them for many moons.
        Worst case go to a boneyard and get the whole plug.
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Tomylee
          No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
          by Tomylee
          Sorry for the person who’s going to read all this !
          I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
          While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
          During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
          07-11-2025, 11:52 AM
        • rex98
          HP DMI Tool
          by rex98
          HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
          DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
          The DMI Tool given here are for personal use only.
          DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
          You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
          from it, and that you please credit the author...
          07-02-2025, 05:51 AM
        • salim5566
          loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
          by salim5566
          Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
          06-26-2025, 03:25 PM
        • CG2
          Meaco Arete One / Deye Dehumidifier not working
          by CG2
          I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
          Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
          08-17-2024, 07:47 AM
