Hi, I have a tcon board that's faulty. I have taken on the tv as a project and would like to know if when testing a resistor for continuity am I right in doing so?
26c resistor
Tags: None
Re: 26c resistor
No, you need test the resistance of it, off the board and check what value it is by the colour code on it, or the numbers if smd, post a picture of it, or tell us the code off it
this link may help, http://samstechlib.com/24614782/en/r...or_Color_Codes -
Re: 26c resistor
Pictures will help. What is it not doing? Blown surface mounted fuse and just have slight glow on the screen and not pictures?Never stop learning
Re: 26c resistor
It's a 26c so that's a 18k ohm resistor right? It's a "no picture, but sound" tv. It's made but acoustic sounds but after a teardown the t-con is a samsung.
Cheers guysComment
--- begin sig file ---
--- end sig file ---Comment
Re: 26c resistor
Backlights on?Never stop learning
by mikey5791Hi to all forum members,
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors... -
by artvandalaiThe resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y3 Photos
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by flat-eartherI have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries.... - Loading...
